Originally Posted by
Trent Tarter
I am recommending a licensed electrician further evaluate.
The proper recommendation is "Fuse panel interior was replaced with a breaker panel interior, now the entire panel, interior and enclosure, need to be replaced."
You are just asking for trouble with a Capital T if you defer to an electrician and do not make the call yourself.
Has any one seen this type of conversion before?
Many times. Replace the panel.
If you call for a replacement and the electrician says otherwise, then something happens *YOU* *STILL* called for replacement - the electrician is on the hook, not you.
