Old 08-17-2007, 12:06 PM
M Kelekci M Kelekci is offline
Should panel be flush?
Is there any requirement in I-Codes or NEC that service entrance equipment/circuit breaker panel should be flush with the wall? Sorry no pix...
Matt Kelekci
Houston TX
Old 08-17-2007, 12:30 PM
Re: Should panel be flush?
I'm sure someone will chime in with the code if there is one... Personally, I don't write it up unless I can't get the screws in easily. The most common thing I see, and what I assume you're talking about, is when the installer didn't account for the thickness of the drywall and just put the front of the panel flush with the front of the framing.
Home inspection
Similar Threads
FPE panel? BARRY ADAIR Electrical Systems: Home Inspection and Commercial Inspection 0 06-07-2007 10:21 PM
Sub Panel David Shipe Electrical Systems: Home Inspection and Commercial Inspection 8 05-26-2007 08:13 AM
Hot tub Panel Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 2 04-12-2007 06:39 PM
vB.Sponsors
Ad Management by RedTyger
