Old 09-13-2007, 10:39 AM
Brian Hannigan's Avatar
Brian Hannigan Brian Hannigan is offline
Administrator
Energy Monitoring Products - What is it?
I had a "What is it?" question come through my e-mail so I thought I'd share it here.
The answer as I understand it is a device/meter for separate tenant billing.
Here is some info.
E-Mon D-Mon Class 1000 Meters
BTW, are referrals from past clients important to you? If so, watch this Video
Sincerely,
Brian Hannigan
Hann Tech Marketing Links
http://www.HannTech.com
http://www.InspectionNews.net
http://www.InspectionRadio.com
http://www.CostOfBusiness.com
http://www.AccessMyReport.com
aaa-CaliforniaHomeInspection.com
http://www.HomeInspectorLocator.com
Old 09-13-2007, 07:19 PM
Jerry Peck's Avatar
Re: Energy Monitoring Products - What is it?
Brian,
That's got me scratching my head ... that would only work (as shown in the photo and material) if each phase supplied one tenant, but that would mean there would be no 240/208 volt circuits, just all 120 volt circuits.
Those were also advertised as being good for separating the load from different departments in one tenant, and that would be done by installing those on the branch circuits feeding that department.
Right now, though, for the photo shown, I'm still trying to figure it out - they are using other than just 120 volt circuits.
Old 09-13-2007, 07:48 PM
Bruce King Bruce King is offline
Check out the wiring diagrams
http://www.emon.com/pdfs/Meter%20Ins...verview%20.pdf
Old 09-13-2007, 07:55 PM
Jerry Peck's Avatar
Bruce,
I did check out all those links.
But ... if you put a current sensing coil on each phase, it will read what is going through each phase, not what is being tapped off a breaker below.
Thus, unless each tenant ONLY has a single phase and the neutral (i.e., 120 volts) how can you tell what Tenant A used between A and B phases and Tenant B used between B and C phase and Tenant C used between phases C and A?
I'm stumped.
Now, if you only had Tenant A on phases A and B and Tenant C on phases B and C, then yes, you don't even need to measure phase B, only Tenant A is on phase A and only Tenant B is on phase C, with phase B being combined load between them, but who cares, you can measure phases A and C.
Right?
Old 09-13-2007, 08:39 PM
fritzkelly fritzkelly is offline
I have seen similar boxes put on by the power company, presumably if they think the meter is bypassed or something. I saw one on a neighboring unit when I was renting a commercial space but don't know if there were the coils in the panel.
  #6 (permalink)
Old 09-13-2007, 10:00 PM
Looks like you have to use the Class 4000 meter for multi-family.
The docs. for the 4000 are not correct, the links come up with 1000,2000,3000 series wiring and not the 4000.
E-Mon D-Mon Class 4000 Meters
It takes more wiring and sensors for the 4000 and they don't have a diagram available on the site.
  #7 (permalink)
Old 09-14-2007, 06:55 AM
Jerry Peck's Avatar
Quote:
Fritz,
I think you saw CT's, Current Transformers, which monitored the current flow through the conductors and displayed the power used on the CT meter. There is a direct relationship between the current through those coils and the voltage output from those coils (they work the same way a transformer works - based on the magnetic fields generated by ac current flow), the voltage output is used to run the power meter and record the power used. I've seen these on several large homes with large amp services.
  #8 (permalink)
Old 09-14-2007, 07:21 AM
TOM DEEHAN TOM DEEHAN is offline
It appears to be a 3 phase panel, could there be one breaker per tenant and the single ones are for common areas in the building?
United Infrared
Similar Threads
Sears Saves Energy - Marketnews.ca Brian Hannigan Inspection News From Around The Net 0 07-28-2007 12:41 AM
Consumer Products Safety Commission (CPSC) feed Carlos Tabora Bugs/Troubleshooting 0 05-22-2007 02:29 PM
SWITCH FROM HIGH HOME ENERGY BILLS TO PERMANENT ENERGY EFFICIENCY - World-Wire (press Brian Hannigan Inspection News From Around The Net 0 04-20-2007 06:00 PM
vB.Sponsors
Ad Management by RedTyger
