09-15-2007, 12:37 PM
Clamp needed?
09-15-2007, 01:31 PM
Re: Clamp needed?
I believe there should be a "red head" bushing, just like the two on the right.
09-16-2007, 02:16 PM
Re: Clamp needed?
Originally Posted by Jeff Eastman
Should these cables ...
They are not "cables", those are "single conductors".
... be clamped where passes through the knockout openings into the panel?
"Cables" - yes; "single conductors", no (because the single conductors are in a raceway).
09-17-2007, 06:06 AM
Re: Clamp needed?
THHN to be exact. I would guess they are running thru conduit behind the drywall which is typical.
RJDalga
Home Analysts, Inc.
Kalamazoo, MI
09-17-2007, 06:44 AM
Re: Clamp needed?
Originally Posted by Robert Dalga
THHN to be exact.
Unless you can read the writing on those conductors better than I can, they could also be THHW, XHHW, XHHW-2 THWN-2, or possibly even THW-2.
09-17-2007, 01:09 PM
Re: Clamp needed?
For clarity on Jerry's initial response:
Jerry, while the answer to "Should these cables be clamped where passes through the knockout openings into the panel?" is YES.... does your response (IF they WERE cables) suggest they would NOT have been properly clamped even with this set-up ?
Or, since there are cable clamps present (bottom section not visible due to in-wall mount) would this suffice as is (if they were cables passing through)?
Dave
09-17-2007, 01:13 PM
Re: Clamp needed?
Sorry, I concede that there may not be "cable clamps" present, but that a "raceway" is more likely present. The round wingnut made me jump to conclusions that a "cable clamp" was present.
09-17-2007, 03:01 PM
Re: Clamp needed?
*IF* a "cable clamp" is present, you have bigger problems than the clamp, that would mean you would be missing the raceway.
09-18-2007, 12:17 PM
Re: Clamp needed?
Jeff,
These are single conductors entering conduit. It seems your question was actually something like "should these be protected from the metal edge of the conduit fitting?" The answer is yes, and there are several products that can accomplish this. Let your client know they will need an electrician.
09-18-2007, 06:55 PM
Re: Clamp needed?
Randy,
Remind me what I am missing, thanks.
09-18-2007, 07:31 PM
Re: Clamp needed?
Randy,
I am going to make an assumption that the raceway is either emt or what we here call greenfield and enters the panel trough a listed fitting. Such a fitting is listed for use without any type of "antishort" bushing.
Making another assumption that this is a residential panel and therefore single phase, why is there a black, red and blue conductor along with a green ground and no neutral? Also what is that black "blob" entering the panel through the fitting just above ( behind) the conduit fittings?
09-18-2007, 11:14 PM
Re: Clamp needed?
UhOh, there's paint on the bottom, that panel will have to be replaced!
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Contractor Needed |
Walter Fish |
Building Envelope: Home Inspection and Commercial Inspection |
2 |
08-09-2007 06:29 PM |
| Electrical help needed |
william siegel |
7 |
06-22-2007 06:30 PM |
| SE needed or not? |
John Stephenson |
Structural Components: Home Inspection and Commercial Inspection |
7 |
05-26-2007 08:22 AM |
| Pictures needed |
Brian E Kelly |
General Chit Chat: Home Inspectors & Commercial Inspectors |
10 |
05-06-2007 06:59 PM |
| Help needed with ID of receptacle |
Michael Thomas |
4 |
04-24-2007 07:50 AM |
