Re: Charred Copper wires in Main Panels
Could be caused by a ground or neutral problem.
Could be caused by an environmental condition, charging batteries, such as for a boat, golf cart, car, etc.
I doubt it was a meth. lab or something like that.
I've seen that in the mildest of forms, i.e., just turning purple on a new construction house with the electrical just being used for temporary power and still under construction.
I've seen it in the worst conditions where the oxidation is falling off and is laying in the bottom of the panel.
I've also seen it in green instead of purple.
Typically, the green is chemical, fertilizer, etc., which are stored open in the same room as the electrical equipment. The worst case of green oxidation I saw included everything copper covered with green corrosion (oxidation), including the copper water pipes in the room, the copper finish door knobs and hinges (but only on the storage room side, the garage side copper door knobs and hinges where not affected). And, yeah, there was an old bag of fertilizer which appeared to have fallen off a shelf many years earlier and split open, and was left there for those many years.
The green oxidation is copper oxidizing.
The purplish color is sulfur oxidizing the copper, such as from the sulphuric acid in the batteries mentioned.
