Old 09-24-2007, 06:17 PM
Clay E White Clay E White is offline
Electrical conduits out of house/deck
Old 09-24-2007, 06:49 PM
Re: Electrical conduits out of house/deck
That liquid tight should have gone into the wood.
No stone shown, but if similar, answer would be the same.
Either that, or stub out with conduit and adapt over to that liquid tight.
Old 09-24-2007, 08:17 PM
Clay,
Not good what I see (or at least what I think I see) in your second photo.
Do those liquid tight conduit run down into the ground? Hope not. If yes, I'll explain why they should not.
Old 09-24-2007, 08:45 PM
The 'proper' way would be to stub out a piece of conduit, install an SLB, and come out the bottom of the SLB with the liquid tight, but, and I can't see it good enough to say it's not good, it 'could be' done like is in the photo ... could be, maybe. Just need to make sure it is sealed at this point, simply because we do not know how it was done.
Be that as it may, when the disconnects are relocated from behind the a/c condenser unit (unless there is 36" between the front of the disconnect and the condenser unit), that would be a good time to 'do it correctly' with a piece of conduit and an SLB.
Are those 'dryer vents' sealed up around the refrigerant lines?
Where is the low voltage wiring, not *in* those liquid tight raceways, I hope.
Old 09-24-2007, 08:57 PM
Rick Hurst's Avatar
It looks like the T-wiring is taped around the outside of the refrigerant line insulation.
We're seeing those dryer vents used for the refrigerant line penetrations quite a bit around here. Some of the AHJ are allowing them.
  #6 (permalink)
Old 09-24-2007, 09:07 PM
Quote:
I'm thinking that is one of the refrigerant lines as it goes to the dryer.
Similar Threads
nails / deck questions Clay E White Exterior Systems: Home Inspection and Commercial Inspection 8 09-25-2007 04:35 PM
A new way to build a deck Scott Patterson Exterior Systems: Home Inspection and Commercial Inspection 10 08-28-2007 08:33 PM
Deck Collapses In The News Bruce Breedlove Exterior Systems: Home Inspection and Commercial Inspection 6 08-04-2007 03:28 PM
Deck flooring dan orourke Exterior Systems: Home Inspection and Commercial Inspection 4 06-20-2007 10:53 PM
Deck framing wayne soper Exterior Systems: Home Inspection and Commercial Inspection 4 05-02-2007 07:49 AM
vB.Sponsors
Ad Management by RedTyger
