Old 09-24-2007, 08:26 PM
dan orourke
Posts: n/a
Electrical cable contact with TV cable
Casey, O'Malley & Associates Home and Commercial Education Classes and Conferences
Old 09-24-2007, 08:38 PM
Jerry Peck's Avatar
Re: Electrical cable contact with TV cable
Too many other things in that photo to worry about, some of which I just have questions on, some of which are needed.
Old 09-25-2007, 06:18 AM
Michael Thomas's Avatar
If something is going to become energized, it's a *whole* lot more likely going to be the case of the furnace where that NM enters it...
My major concern where Lo Volt is in physical contact with AC is at the exterior, especially the service drop, where wires are subject to physical abrasion, UV damage, and are going to get wet.
Old 09-25-2007, 08:34 AM
Robert Schenck's Avatar
Robert Schenck Robert Schenck is offline
To me, .... Probability says "No", .... but then Murphy's Law says "Yes".
Robert
Roberts Home Inspection Service
Old 09-25-2007, 04:59 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Gentlemen,
If that furnace is rated to lay on it's side Why do the installation instructions Read bottom
to Top and Gas line routed under?
I still do not Like Styrofoam as supports for Heating Appliances.
If you have ever seen it burn you would know why.
Billy J. Stephens HI Service
  #6 (permalink)
Old 09-25-2007, 05:19 PM
Jerry Peck's Avatar
Quote:
Originally Posted by Billy Stephens View Post
If that furnace is rated to lay on it's side Why do the installation instructions Read bottom to Top and Gas line routed under?
Now you are getting to one of the items I was asking about (but had not asked about yet, I was waiting for other to pick up on it).
That unit 'looks to me' like it is designed to be installed vertically.
From the air vent (which would be horizontal if installed vertically) to the unseen 'is the gas burner and heat exchange designed to be installed on its side like that? To other questions.
  #7 (permalink)
Old 09-25-2007, 06:23 PM
Gas flex line has a severe indent in it.
Not sure of the material of apr 10 inch nipple appears corroded.
Drain system looks questionable.
Still DO NOT LIKE STYROFOAM.
  #8 (permalink)
Old 09-25-2007, 06:27 PM
Jerry Peck's Avatar
Billy,
You saw the crimp too ...
Adding to your list ...
No sediment trap.
Guys, and gals, keep adding to the list.
  #9 (permalink)
Old 09-25-2007, 06:36 PM
I can only see so much on 12" laptop with no ZOOM.
STILL DO NOT LIKE STYROFOAM.
Buy thats just me.
  #10 (permalink)
Old 09-25-2007, 08:47 PM
Matt Fellman Matt Fellman is online now
Quote:
Billy,
No sediment trap.
Rust in the pan under the evap coils - clogged overflowing condensate or coils? Is that evap even meant to lay sideways?
What is that 'goo' around the line set where it enters the evap?
What kind of tape is that around the edges of the evap?
  #11 (permalink)
Old 09-25-2007, 09:17 PM
Nolan Kienitz's Avatar
Nolan Kienitz Nolan Kienitz is offline
Flex appears to be passing through side wall of furnace. "Not allowed"!!
As Jerry indicated looks like a vertical unit at rest on it's side.
Cheers - Nolan E. Kienitz, HCRI
Dallas Home Inspector
www.NolansInspections.com
  #12 (permalink)
Old 09-25-2007, 09:50 PM
Rick Hurst's Avatar
NM cable entering the cabinet without a connector.
Wiring on the decking is a trip hazard.
Looks like possible white teflon tape on the right side gas line connections.
Rust in pan.
No trap on secondary line.
No visible electrical disconnect at equipment.
T-lines are not capped
Wiring laying across the emergency drain pan.
And there is some rodent droppings behind that equipment.
FREA Home Inspector Insurance
Similar Threads
Electrical cable routing RobertSmith Electrical Systems: Home Inspection and Commercial Inspection 4 09-09-2007 08:56 AM
exterior electrical cable. Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 6 07-06-2007 06:14 PM
Electrical cable location Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 0 06-22-2007 04:57 PM
Air ducts/electrical cable RobertSmith Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 1 06-06-2007 08:52 PM
Electrical cable routing Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 2 06-05-2007 09:39 PM
vB.Sponsors
Ad Management by RedTyger
