Re: Dryer outlet in foundation wall
Mr. No First Name Davidson,
All boxes need covers.
DO NOT USE *plastic* OR *foil* dryer vent connectors NEITHER *is allowed*.
The NM cable to the dryer outlet needs to protected from physical damage.
The sump pump IS REQUIRED to have GFCI protection, do not recommend that GFCI be removed.
That one 'extension cord' looks like lamp cord and that is a no-no.
What did the yellow extension cord go to? Extension cords are not allowed to replace permanent wiring methods, if it went to something 'permanent' then a circuit needs to be extended over to whatever it was.
You would need to have at least #10 going to the dryer outlet (30 amps), and, if the circuit ran very far, you might want to use #8 to reduce voltage drop problems.
