Old 12-03-2007, 11:23 PM
GFI info from UL
UL | Underwriters Laboratories Advises Consumers Regarding Ground Fault Circuit Interrupters (GFCIs)
I just found this while surfing around..... Sorry if it's already around here somewhere.
Home inspection
Old 12-04-2007, 05:52 AM
John Arnold John Arnold is online now
Re: GFI info from UL
Interesting that they recommend replacement of the GFCI if it trips while doing its job, i.e., when a defective appliance causes a ground fault. I hate throwing things away for no good reason. Seems to me that if it still functions properly, if it trips and resets when tested, why not keep it?
Old 12-04-2007, 06:31 AM
Re: GFCI info from UL
Quote:
Not quite what they said, at least not what I read: (bold is mine)
UL recommends that the GFCI be replaced by a qualified electrician if:
  • The lamp or other appliance plugged into the GFCI remains "ON" when the "Test" button is pushed.
  • The GFCI does not reset when the "Reset" button is pushed.
  • The GFCI performs its intended function, but trips repeatedly during normal use. (This may indicate either a faulty appliance or a compromised GFCI. In either case, replacement of the GFCI is recommended and the appliance should be checked for proper operation prior to reuse.)
Did I miss something else in that letter?
Matt, thanks for posting that link.
Old 12-04-2007, 06:41 AM
Jerry - You're right in that I kind of overlooked that "repeatedly during normal use", but they still seem to be saying the same thing, which is that even if the GFCI is functioning properly, and the problem is with the appliance, they recommend replacing the GFCI.
Now, does using the test button once a month constitute tripping "repeatedly"?
Old 12-04-2007, 06:48 AM
Only when it "trips repeatedly during normal use. (This may indicate either a faulty appliance or a compromised GFCI. In either case, replacement of the GFCI is recommended and the appliance should be checked for proper operation prior to reuse.)", if the appliance has a problem and trips the GFCI, the GFCI is reset, and does not trip "repeatedly" in that "normal use" of the GFCI, then they are not recommending it be replaced.
Tripping repeatedly could indicate a problem with the GFCI, could cause a problem with the GFCI, could indicate a problem with the appliance ... those could and/or issues, occurring singly or together, and rather than take chances, they are saying to replace the GFCI and address the appliance.
(see bold below)
"Testing" is not "normal use".
  #6 (permalink)
Old 12-04-2007, 07:31 AM
I'm making an assumption about the reason for replacing the GFCI if it trips repeatedly during normal use due to a faulty appliance. My assumption is that UL is concerned that the GFCI may be damaged by the repeated tripping. (I know I was!) Hence, my question about testing. If testing is essentially doing the same thing that the faulty appliance is doing, then won't testing also damage the GFCI?
Home inspection
Similar Threads
Info on Rheem REAB 1415 J Jim McClendon Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 09-15-2007 10:47 AM
Truss Uplift Info needed Bill Wieczorek Attic Areas: Home Inspection and Commercial Inspection 18 09-07-2007 09:43 PM
Member info... Eric Shuman H E L P ! 3 08-06-2007 12:11 PM
Safety glass info Richard Stanley Building Envelope: Home Inspection and Commercial Inspection 3 06-01-2007 08:49 PM
Infrared training info Richard Stanley Tools and Equipment 0 04-04-2007 03:40 PM
vB.Sponsors
Ad Management by RedTyger
