Old 12-08-2007, 09:37 AM
Zibby Swieca Zibby Swieca is offline
How would you write this up
How would you write this up.
Old 12-08-2007, 10:04 AM
Richard Stanley Richard Stanley is offline
Re: How would you write this up
Open knock outs in j-box and panel.
debris in panel.
Double lugged breakers - looks like.
Can't tell - Are breakers rated for aluminum, Is wire size correct?
Old 12-08-2007, 10:35 AM
Jesse R Reyes Jesse R Reyes is offline
Appears that there is a meter next to the panel. There should be a main breaker. The aluminum wire is blistering. Overload. The panel is in hazards conditions. Recommend that the panel be Ungraded and that an Electrical Contractor may further evaluations.
Old 12-08-2007, 11:42 AM
Scott Patterson's Avatar
Quote:
I would report; "This is a fire waiting to happen. Call an electrician now".
Scott Patterson
Old 12-08-2007, 05:26 PM
Michael Thomas's Avatar
Closer look:
  #6 (permalink)
Old 12-08-2007, 06:42 PM
"Open knock outs in j-box ... "
Non-weatherproof box and cover not rated for use outdoors and installed outdoors, also has open knock out - replace with weatherproof box and cover approved for use outdoors (i.e., in "wet locations").
Is that asbestos cement siding shingles?
Service equipment has melted insulation which indicates overheating, typically caused by loose connections.
Service equipment currently has 5 main breakers and space for one more, make sure not to install two breakers in the remaining double pole main breaker location.
Open knock outs in service equipment has allowed animals/birds to bring combustible debris into the enclosure, combustible debris is in contact with, or close proximity to, energized components - this could lead to fire or electrical shock. Open knock out into wall cavity allows animals/birds to enter into the wall cavity.
What appears to be the grounding electrode conductor is bolted together - if this is the grounding electrode conductor this is not allowed until after the first grounding electrode,
That will do for starters to get and electrical contractor out there to correct everything you listed, and everything they find, and everything they create while making corrections.
  #7 (permalink)
Old 12-08-2007, 06:44 PM
Donald Merritt Donald Merritt is offline
Look for a dead bird or mouse.
  #8 (permalink)
Old 12-08-2007, 06:54 PM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is offline
Breakers installed with "on" in the down position.
I like Scott's but always find it necessary (in my own mind and in good reporting practices) to expound a little bit on "why" it's a fire hazard.
Erby Crofutt, Georgetown, KY
B4U Close Home Inspections & Radon Testing
www.b4uclose.com www.kentuckyradon.com
  #9 (permalink)
Old 12-08-2007, 07:07 PM
James Duffin James Duffin is offline
It looks like a NEMA 3R box mounted sideways. It's made to be mounted verticle...not horizontal.
  #10 (permalink)
Old 12-08-2007, 07:12 PM
Erby, James,
The photo was just taken sideways. The box (enclosure) is installed vertically - look at the grain in the siding.
I know, photos should always be taken with 'up' being 'up', or, when trying to fit more into the photo, rotating the photo before using it anywhere so that 'up' is 'up'.
  #11 (permalink)
Old 12-09-2007, 08:00 PM
Jerry McCarthy's Avatar
Don't forget "over-fusing!"
Construction Consultant
  #12 (permalink)
Old 12-10-2007, 12:24 PM
Shannon Guinn Shannon Guinn is offline
Quote:
I concur with Scott.
  #13 (permalink)
Old 12-10-2007, 12:25 PM
I also concur with Jerry.
Home inspection
Similar Threads
How to write up dan orourke Plumbing System: Home Inspection and Commercial Inspection 26 11-20-2007 09:44 AM
How to write up Clay White Roofing System: Home Inspection and Commercial Inspection 15 10-25-2007 07:39 PM
How to write this up Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 1 07-09-2007 10:46 PM
How would you write this up wayne soper Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 04-05-2007 07:28 PM
vB.Sponsors
Ad Management by RedTyger
