Old 04-12-2007, 11:22 AM
Hot tub Panel
Home inspection
Old 04-12-2007, 02:33 PM
Re: Hot tub Panel
*IF* that ground lug is attached at the proper location in that enclosure, and it looks like it is not. There looks to be a raised dome with a flat top, most likely with a screw hole in the center of it, just to the right of the neutral terminal bar, this is where the ground terminal 'should be' (if I am seeing correctly) attached.
If that were the case, and *if* that ground terminal was rated for 2 equipment ground conductors, then okay - but - not all of those smaller single terminals are rated for 2 equipment ground conductors.
It would be better and safer to have just installed a multiple terminal lug in the correct location. That would also eliminate any questions raised by this installation.
Old 04-12-2007, 05:39 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is offline
Re: Hot tub Panel
Well they did say they wanted a "HOT" tub.
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
Home inspection
Similar Threads
2 Wire Load Side Fuse Panel Michael Thomas Electrical Systems: Home Inspection and Commercial Inspection 2 04-12-2007 02:22 PM
Transformer & Low Volt Wiring in Main Panel Shane Pouch Electrical Systems: Home Inspection and Commercial Inspection 3 04-10-2007 08:19 AM
From the old board, Wet Panel Tim Moreira Electrical Systems: Home Inspection and Commercial Inspection 0 04-01-2007 11:38 PM
vB.Sponsors
Ad Management by RedTyger
