You are currently viewing InspectionNews as a guest which gives you limited access to view most discussions but not pictures. There are over 4,500 inspectors who have already joined. By joining InspectionNews you will be able to see the pictures, have access to post topics, communicate privately with other members, respond to polls, upload content and access many other special features. Registration is fast and simple so please, join InspectionNews today!
Old 12-10-2007, 03:20 PM
dan orourke dan orourke is offline
60amp breaker/aluminum wiring
Old 12-11-2007, 06:03 AM
Re: 60amp breaker/aluminum wiring
Quote:
Originally Posted by dan orourke View Post
Breakers (40,60amp) for with stranded aluminum conductors should be rated for aluminum wiring, right? I didn't see a rating stamp on the 60 amp breaker.
It's probably there someplace.
Quote:
Originally Posted by Jeff Eastman View Post
Here is my question: Are you allowed to used that stranded copper for bonding the bus bar to the panel? Could that had cause the overheating?
That is solid copper, and, no, it is not a proper grounding bond, plus (oh no, here goes this discussion again) that is under a sheet metal screw into the back of the cabinet, which is not allowed. The arcing does appear to be around the ground bond connection to the neutral terminal bar, could be loose, but, if that is the cause of that arcing, then there was some high ground current going where there none is intended (i.e., something happened and that current went to ground there).
Kinda looks like that neutral crossing through between the breakers (which is should not do) may have arced through to the hot terminal.
Construction / Litigation Consultant www.ConstructionLitigationConsultants.com
Similar Threads
FPE Stab-Lok Panel and Aluminum Wire Chris Skoczylas Electrical Systems: Home Inspection and Commercial Inspection 20 08-03-2007 05:57 PM
Aluminum wiring pigtails in the IRC? Eric Laney Electrical Systems: Home Inspection and Commercial Inspection 2 07-18-2007 11:16 PM
Strange Aluminum Roof Matt Hawley Roofing System: Home Inspection and Commercial Inspection 14 07-04-2007 09:06 AM
Aluminum Wiring allen elliott Electrical Systems: Home Inspection and Commercial Inspection 3 06-14-2007 05:25 PM
New Aluminum connector Jim Robinson Electrical Systems: Home Inspection and Commercial Inspection 1 05-22-2007 12:51 PM
vB.Sponsors
Ad Management by RedTyger
