Old 04-18-2007, 04:07 PM
Light switch position.
Old 04-18-2007, 04:55 PM
Jim Robinson's Avatar
Jim Robinson Jim Robinson is offline
Re: Light switch position.
If it's a standard switch without an On and Off marking, it is probably a three way. If it's the Decora type, then there are no markings, and it could be either. I probably would mention it, depending on what else is present. It would bug me if it were my house and I would have to rotate it if it was installed upside down. Easy enough to correct.
Old 04-18-2007, 05:08 PM
Now, *if* you removed the cover plate, you would see "TOP" stamped into the yoke the switch is in. That "TOP" *should* (as in *shall*) be at the top.
110.3(B) Listing and labeling. It is required to be installed, and used, in accordance with its listing and labeling (my wording, not a code quote).
So, technically, for single pole switches, 'ON' *should* be up, and 'OFF' *should* be down.
There may be 3-way switches, in which case the 'ON' is up and 'OFF' is down will change depending on which switch is in which position. You will also find that 3-way switches are not marked with a 'TOP'.
Old 04-18-2007, 05:11 PM
Richard Rushing's Avatar
My money is on a 3-way...
Rich
Old 04-18-2007, 07:03 PM
Tim Moreira's Avatar
Tim Moreira Tim Moreira is offline
yepper
Similar Threads
light bulb beats pvc John Arnold Plumbing System: Home Inspection and Commercial Inspection 7 04-16-2007 02:46 PM
From the old board, light bulbs incessantly burning out Tim Moreira Electrical Systems: Home Inspection and Commercial Inspection 0 04-02-2007 12:55 AM
vB.Sponsors
Ad Management by RedTyger
