You are currently viewing InspectionNews as a guest which gives you limited access to view most discussions but not pictures. There are over 4,500 inspectors who have already joined. By joining InspectionNews you will be able to see the pictures, have access to post topics, communicate privately with other members, respond to polls, upload content and access many other special features. Registration is fast and simple so please, join InspectionNews today!
Old 03-16-2008, 03:10 PM
Jerome W. Young Jerome W. Young is online now
80 amp main
Had a 1958 home that only had an 80 amp main. Any problem with that? I know 100 is the min now... but back then?
Old 03-16-2008, 03:51 PM
Rick Hurst's Avatar
Re: 80 amp main
Its a 50 yr. old service equipment and needs to be replaced.
Old 03-16-2008, 05:12 PM
David Banks David Banks is offline
Re: 80 amp main
Quote:
Many homes built in the 50's with 60 Amp main. Like Rick said. Replace it Fuses!
Dave
Old 03-16-2008, 06:59 PM
Jim Luttrall Jim Luttrall is online now
Re: 80 amp main
Insurability is an issue with some insurance companies with anything over 40 years. Electrical systems are not like fine wine, they do not get better with age.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 03-16-2008, 08:39 PM
Re: 80 amp main
1956 NEC - 60 amp minimum
1959 NEC - 100 amp minimum
Regardless, though, will 60 amp carry what is in the typical modern house? Not likely.
Construction / Litigation Consultant www.ConstructionLitigationConsultants.com
  #6 (permalink)
Old 03-16-2008, 08:55 PM
Richard Rushing's Avatar
Re: 80 amp main
I usually tell the buyers...
"We are no longer living in the 40's and 50's. What their household appliances and equipment required back then is much different from what we require these days. You don't want to be limited to having to live as they did back then. You are probably wanting to upgrade alot of the things in this home anyway... just plan on doing the same with the electrical accordingly."
rr
Richard Rushing, HCRI
Duncanville, Tx.
  #7 (permalink)
Old 03-17-2008, 04:16 AM
Re: 80 amp main
Roger...thanks
  #8 (permalink)
Old 03-17-2008, 06:41 AM
John Steinke's Avatar
John Steinke John Steinke is offline
Re: 80 amp main
The size of the service is probably just fine. One needs to do a load calculation, or take measurements, to be able to say there's a problem.
Indeed, one could argue that supplying 80 amps to a home that only needs, say, 50 amps, is safer than supplying it with 100 amps.
I'd never advise a service change simply because the equipment was 'old.'
Age is a clue, though. Apart from the actual condition of the equipment, it's a suggestion that you look for improper electrical work that has been done over the past fifty years. That's where the dangers are found.
Heck, until recently my place was doing just fine with two circuits, and a 30 amp, 120 volt service. I certainly never blew a fuse ..... and yes, they were the right sizes
Naturally, my old service would not have been able to handle the addition of an electric range, electric water heater, air conditioning, or a electrically heated hot tub.
Yet, even with a fancy new breaker panel, my home's electrical system is unchanged - all I have is a big box with empty spaces. The wiring inside the house hasn't changed a bit since 1940. Two circuits, no ground wire, very few outlets.
In that regard I'm lucky. No flying splices, no 3-prong receptacles, no confused shared neutrals .... even at the light fixtures, there' been little over-lamping (as the insulation hasn't turned to dust). Those are the types of things to focus on.
  #9 (permalink)
Old 03-17-2008, 07:26 AM
Richard Abrams Richard Abrams is offline
Re: 80 amp main
Replace it Do you still drive a 1958 car? Minimum in Idaho is 125Amp.
Arguing with an inspector is like wrestling a pig in the mud, pretty soon you realize the pig enjoys it.
  #10 (permalink)
Old 03-17-2008, 08:07 AM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
Re: 80 amp main
Quote:
Nope 57 Truck.
Billy J. Stephens HI Service
Similar Threads
main panel Jerome W. Young Electrical Systems: Home Inspection and Commercial Inspection 7 01-04-2008 01:37 PM
FPE main disconnect Paul Kondzich Electrical Systems: Home Inspection and Commercial Inspection 2 06-20-2007 05:52 PM
Main service panel? Mark Muehleisen Electrical Systems: Home Inspection and Commercial Inspection 1 06-05-2007 12:09 PM
Main breaker rating RobertSmith Electrical Systems: Home Inspection and Commercial Inspection 4 06-01-2007 11:48 AM
Double at Main Nick Ostrowski Plumbing System: Home Inspection and Commercial Inspection 8 05-19-2007 11:05 AM
vB.Sponsors
Ad Management by RedTyger
