Old 04-08-2008, 10:30 PM
william siegel's Avatar
william siegel william siegel is offline
Ground wires
Thoughts guys. Here are two separate ground wires pigtailed on a connector and then connected to the ground bar. Contractor says it is correct. I say no. Who is right.
File Type: jpg 571 SE 3 Terr Pompano(Tetrauldt) 022.jpg (46.5 KB, 47 views)
Bill Siegel
Florida Home Inspection Team Inc.
Home inspection
Old 04-08-2008, 10:42 PM
Re: Ground wires
That's always been the preferred method with load conductors as opposed to a double tapped breaker. Assuming it doesn't overload the circuit (a grand assumption, I realize).
Are there no more open slots on the ground bus? Yes, it would be better to have each wire attached to the bus but I can't say it's 'wrong' the way it's done.
I'd never call it out.... it's approaching splitting hairs.... jmo
Old 04-09-2008, 06:55 AM
Re: Ground wires
Quote:
That works well because the overcurrent device is in the circuit, thus, regardless how many #12 wires you have, you are protected at 20 amps maximum though the total of them, and through the one of them.
Not a problem there.
I would say it is wrong in that two or more grounds 'could easily be' from more than one circuit, thereby *not* having one breaker to protect against overcurrent for any given conductor.
Most ground bars now allow up to two (some even three, but only is so stated) ground wires in the same terminal hole if the same size and same material (copper).
I'd let them 'do it right' and eliminate the wire nut. *IF* the wire nut was only used to allow each to be made longer, that would not be a problem, but putting two into one 'could be'.
Old 04-09-2008, 10:16 AM
Richard Abrams Richard Abrams is offline
Re: Ground wires
Electrician is right This junction is made in an approved junction box.
Arguing with an inspector is like wrestling a pig in the mud, pretty soon you realize the pig enjoys it.
Similar Threads
circuit wires in front of main service wires Jerome W. Young Electrical Systems: Home Inspection and Commercial Inspection 3 03-15-2008 05:29 PM
how many neutral wires CHARLIE VAN FLEET Electrical Systems: Home Inspection and Commercial Inspection 5 03-04-2008 06:55 AM
Bundled wires... Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 24 12-04-2007 06:21 AM
Messy wires william siegel Electrical Systems: Home Inspection and Commercial Inspection 13 04-18-2007 09:21 AM
Discoloration on Insualtion of wires Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 3 04-15-2007 11:06 PM
vB.Sponsors
Ad Management by RedTyger
