Old 04-25-2007, 06:36 PM
william siegel's Avatar
william siegel william siegel is offline
condo panel box
What do you guys think about this box. I have two questions:
1. what would cause the rust inside a condominium
2. Maybe I am missing something, but I have never seen a box with all of the holes above the bus bar. Any ideas??
File Type: jpg 2401 N Ocean Blvd #2N Boca Raton(LeMay) 017.jpg (26.2 KB, 70 views)
Bill Siegel
Florida Home Inspection Team Inc.
Old 04-25-2007, 06:40 PM
Jim Luttrall Jim Luttrall is online now
Re: condo panel box
Is this on the outside wall? Could be condensation causing the rust...
Can't tell much about the holes.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 04-25-2007, 06:49 PM
John Arnold John Arnold is online now
Re: condo panel box
Many of the condos I've inspected had poor bath ventilation and poor dryer ventilation, therefore, high humidity.
I have no idea about the holes above the bus bar.
Old 04-25-2007, 06:51 PM
Re: condo panel box
Jim,
It on an inside wall in the utility room.
John,
It is in front of the dryer, which was vented ok. Maybe the old dryer was not venting so good. I did not think of that one.
Bill Siegel
Old 04-25-2007, 06:56 PM
Re: condo panel box
After I posted my question, I realized how ambiguous it was.
Was the box mounted on the inside of the house on an exterior wall?
That might make enough temperature differential to drive moisture into the cooler surface inside the box.
Might also happen the same way in a warm moist laundry room with cooler surroundings.
Jim
Allen, Texas 75002
  #6 (permalink)
Old 04-25-2007, 07:10 PM
dick whitfield
Posts: n/a
Re: condo panel box
Would guess the panel is about 15-20 years old. Looks typical for that age. How did the breaker connections look?
  #7 (permalink)
Old 04-25-2007, 07:22 PM
Re: condo panel box
Dick,
You hit the nail on the head with the age - actually about 24 years old. All the connections looked OK.
Bill Siegel
  #8 (permalink)
Old 04-25-2007, 08:11 PM
Re: condo panel box
The holes are for different panelboard interiors which could be mounted in that enclosure.
Also looks like some low voltage in there from the size of the conductors at the top.
  #9 (permalink)
Old 04-25-2007, 08:41 PM
Richard Rushing's Avatar
Re: condo panel box
That actually looks like a panel that was re-populated/ stuffed.
RR
  #10 (permalink)
Old 04-26-2007, 06:45 AM
Richard Stanley Richard Stanley is offline
Re: condo panel box
Rust?
Humid salt air - just like here.
It is in or near the coast - Miami area.
Doors or windows left open often.
You mentioned utility room - was it in the laundry room? I have heard of open bottles of bleach contributing to corrosion.
  #11 (permalink)
Old 04-26-2007, 07:40 AM
Re: condo panel box
Quote:
RR
I think Richard might be right on that.
Of course, though, that would mean the panel was 'a violation of the code' as it would not longer meet 110.3(B) as it was no longer 'being used in accordance with its listing and labeling'.
Which means the entire panel needs to be replaced, unless, of course, the person who replaced the panel interior kept the enclosure for that panel interior, or someone buys an enclosure listed for that panel interior.
Similar Threads
Hot tub Panel Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 2 04-12-2007 05:39 PM
1976 Slyvania panel Warren Alderman Electrical Systems: Home Inspection and Commercial Inspection 3 04-12-2007 04:06 PM
2 Wire Load Side Fuse Panel Michael Thomas Electrical Systems: Home Inspection and Commercial Inspection 2 04-12-2007 02:22 PM
Transformer & Low Volt Wiring in Main Panel Shane Pouch Electrical Systems: Home Inspection and Commercial Inspection 3 04-10-2007 08:19 AM
From the old board, Wet Panel Tim Moreira Electrical Systems: Home Inspection and Commercial Inspection 0 04-01-2007 11:38 PM
vB.Sponsors
Ad Management by RedTyger
