You are currently viewing InspectionNews as a guest which gives you limited access to view most discussions but not pictures. There are over 4,500 inspectors who have already joined. By joining InspectionNews you will be able to see the pictures, have access to post topics, communicate privately with other members, respond to polls, upload content and access many other special features. Registration is fast and simple so please, join InspectionNews today!
Old 05-05-2008, 07:57 PM
Ross Neag Ross Neag is offline
Subpanel quickie
OK, AMONG OTHER PROBLEMS, this garage subpanel is fed from a 60 amp breaker in the house. Pic 1 is the home and Pic 2 is the garage. How would you word the 100 amp main in the garage other than WRONG!
Home inspection
Old 05-05-2008, 08:00 PM
Re: Subpanel quickie
Forgot these...
Old 05-05-2008, 08:08 PM
Quote:
There is nothing wrong with feeding a 100 amp breaker or panel from a 60 amp breaker or panel, the most you have available for *ALL* panels is still 60 amps.
There is also nothing wrong with having a main in each panel (in fact, I prefer it, for safety reasons, just absolutely no requirement for it). All you need to remember is that that second main is 'not service equipment' and to treat it as such, i.e., neutral isolated from ground.
Construction Consultant
Old 05-05-2008, 08:12 PM
Richard Rushing's Avatar
*If* you are absolutely sure that the garage is fed from the panel shown on the left (the main), then the equipment panel in the garage should have the neutral and ground bar removed-- isolating the neutrals and the grounds.
You must make sure that this is the case (garage fed from the home/main panel).
Rich
Richard Rushing, HCRI
Duncanville, Tx.
Old 05-05-2008, 08:15 PM
Well, upon closer look... it appears that both (bar) sides of the garage panel are connected with neutrals only. I cannot see any grounds. My bad (if that's the case).
RR
Duncanville, Tx.
  #6 (permalink)
Old 05-05-2008, 08:19 PM
RR, that's what I saw too. I convinced myself that the 100 amp breaker would allow too much current but forgot what was feeding it
thanks for the help gents.
Similar Threads
Condo Subpanel Wiring Question Reis Pearson Electrical Systems: Home Inspection and Commercial Inspection 4 03-17-2008 07:34 AM
vB.Sponsors
Ad Management by RedTyger
