Old 05-08-2008, 03:36 AM
Jerome W. Young Jerome W. Young is offline
bulldog push matic
I believe this is fused? again i did not open it. Any history of concerns with this type main, other than being 45 + yrs old.
Home inspection
Old 05-08-2008, 04:48 AM
Aaron Miller Aaron Miller is offline
Senior Member
Re: bulldog push matic
In a word, obsolete.
According to the NAHB Study of Life Expectancy of Home Components electrical "accessories" are rated at 10+ years. I would venture to say that 45 years is beyond this unit's service life.
Aaron
Old 05-08-2008, 07:44 AM
Scott Patterson's Avatar
Quote:
It is a breaker and not a fuse. As Aron said it is old. Bulldog pushmatics have very few problems, except that they are old.
Scott Patterson
Old 05-08-2008, 03:58 PM
Corey Friedman Corey Friedman is offline
Quote:
Hi Scott,
I'll bet ya a steak at Gibson's (next time you are in Chicago) that this a fused (or un-fused) disconnect switch but not a breaker.
Corey
Old 05-08-2008, 04:00 PM
Quote:
Originally Posted by Corey Friedman View Post
Hi Scott,
Corey
Corey,
Scott will be buying ... select the thickest cut they have.
  #6 (permalink)
Old 05-08-2008, 06:41 PM
Randy Clayton Randy Clayton is offline
I'm going with Corey on this one. You open that box and you will find fuses (i could not tell from that pic the size or phase type) But that is strictlley a disconnect box with fuses inside!!!!!
  #7 (permalink)
Old 05-09-2008, 10:09 AM
Corey, I'll be in Chicago next week. I' be in town from the 15th-17th. How's Steak and Shake!
Scott Patterson
  #8 (permalink)
Old 05-09-2008, 03:23 PM
Steak-n-Shake it is!
  #9 (permalink)
Old 05-10-2008, 08:56 AM
Evan Grugett Evan Grugett is offline
This is probably a main switch (the plate reads 100 amps 240 volt) and is not fused. These boxes should really be opened if at all possible and the interior inspected for cable size, cable material on the line and load side, and problem conditions (taps, corrosion, etc..). This is +35 year old equipmentIn these parts licensed electricians say that Bulldog Pushmatic breaker panels are hard to get replacement parts for and so I warn the client on that in my report.
Evan Grugett
Home inspection
Similar Threads
Double tap off main disconnect/ Bulldog Pushmatic Paul Kondzich Electrical Systems: Home Inspection and Commercial Inspection 7 03-04-2008 08:30 AM
vB.Sponsors
Ad Management by RedTyger
