Old 05-08-2008, 07:50 PM
Michael Vasquez Michael Vasquez is offline
Aluminum wiring with AFCI breakers
Inspected this house today and the seller has had the sub panel (15 and 20 amp circuits) replaced and the new panel now has every circuit on AFCI breakers. House is wired with aluminum wire. Will this panel be protecting all aluminum circuits throughout the house properly? I have never seen this before.
Also, some of the older receptacles were not CO/ALR and the aluminum wires have been pigtailed with copper using lavender wire connectors. I now these connectors are not quite safe and other type of connectors are recommended. What would be the best way to report on this?
Thank You
Old 05-08-2008, 07:56 PM
Jerry Peck's Avatar
Re: Aluminum wiring with AFCI breakers
That is one of the original intended uses for AFCI breakers.
Old 05-09-2008, 06:33 PM
Matthew Barnicle Matthew Barnicle is offline
Sounds like that is about the best they can do if they are keeping the original aluminum branch circuits. Don't know much about the lavender connectors but I believe they are designed for this purpose, no?
Old 05-09-2008, 08:33 PM
James Duffin James Duffin is offline
Quote:
Jerry...
Where can I find info on that? I did four townhouses in the past two weeks that had aluminum wiring. I would love to be able to give this option as a repair. I advise against the pigtail fix.
Old 05-09-2008, 08:42 PM
Jerry Peck's Avatar
Check on the CPSC site, they should have something on there about AFCIs and the reason they came about, I think I read something on their site about that.
  #6 (permalink)
Old 05-09-2008, 08:55 PM
Thanks...I've haven't been there is a while so I'll check for new info. I'll let you know what I find.
  #7 (permalink)
Old 05-09-2008, 08:57 PM
Jerry Peck's Avatar
Quote:
James,
I believe it was a couple of years ago or so.
  #8 (permalink)
Old 05-09-2008, 09:25 PM
Jerry Peck's Avatar
CPSC, ESFI Warn Consumers About Electrical Hazards In The Home "Inspect and Protect!" Campaign Encourages Homeowners to Safeguard Homes
(underlining is mine - maybe I just added 2+2+2 and got 6)
"This summer, CPSC and ESFI are encouraging homeowners to: 1) have an electrical inspection conducted for homes 40 years and older, for homes 10 years and older with major renovations or new appliances added, or that have been resold; 2) learn the potential hazards posed by aluminum wiring systems and contact CPSC if your home is among the two million built with aluminum wiring between the late 1960s and early 1970s; and 3) consider installing arc fault circuit interrupters in place of ordinary circuit breakers, especially if your home is over 40 years old. AFCIs are new technology designed to prevent electrical fires by sensing unseen electrical arcing. AFCIs are particularly important where wiring may have degraded with age."
http://www.cpsc.gov/LIBRARY/FOIA/FOI...FCImeeting.pdf
Slide on page 22 of 38, Enhanced Protection, Currently available AFCIs provide protection beyond standard breakers and fuses: aluminum wiring (then other things listed)
FREA Home Inspector Insurance
Similar Threads
AFCI Breakers or NOT Al Roden Electrical Systems: Home Inspection and Commercial Inspection 60 05-14-2008 02:09 PM
Aluminum wiring to branch circuits dan orourke Electrical Systems: Home Inspection and Commercial Inspection 10 12-12-2007 02:04 PM
60amp breaker/aluminum wiring dan orourke Electrical Systems: Home Inspection and Commercial Inspection 1 12-11-2007 07:03 AM
Aluminum wiring pigtails in the IRC? Eric Laney Electrical Systems: Home Inspection and Commercial Inspection 2 07-19-2007 12:16 AM
Aluminum Wiring allen elliott Electrical Systems: Home Inspection and Commercial Inspection 3 06-14-2007 06:25 PM
vB.Sponsors
Ad Management by RedTyger
