You are currently viewing InspectionNews as a guest which gives you limited access to view most discussions but not pictures. There are over 4,500 inspectors who have already joined. By joining InspectionNews you will be able to see the pictures, have access to post topics, communicate privately with other members, respond to polls, upload content and access many other special features. Registration is fast and simple so please, join InspectionNews today!
Old 05-13-2008, 07:15 AM
Nick Ostrowski Nick Ostrowski is offline
Denergizing Panel Requirement
Does anybody have an idea how long it has been required for service panels to need no more than 6 throws of the hand to denergize the entire panel? I saw an older split bus panel yesterday that needed 10 throws to shut it down.
Old 05-13-2008, 07:27 AM
Re: Denergizing Panel Requirement
I don't think there was ever a time 10 was okay. All I've ever heard was 6 and now 1. I suppose it's possible that there was a time period that it just wasn't addressed so you could find anything.
But really, circuit breakers didn't come about until the 50's/60's and by the 60's I'm pretty sure it was the 6 throws of the hand rule. I seem to remember even the old Pushmatic panels from the 50's/60's had a 'sub-main' and fell under the 6 switches.
Old 05-13-2008, 09:14 AM
Quote:
Back before time began ...
If there were more than 6 in the section which serves as the main (and which controls the other section), then it was improperly done, with improper breakers (the label will show a schematic showing the double pole breakers in the 'main' section, and it probably will not show any single pole breaker in that section - because that would allow the total number of 'mains' to exceed 6).
Construction / Litigation Consultant www.ConstructionLitigationConsultants.com
Old 05-13-2008, 12:00 PM
Richard Abrams Richard Abrams is offline
6 disconnects is still the rule However these need to be grouped together and labeled. I have been in business since 1977 and there was never 10 disconnects allowed. Also becareful if it is a split bus panel as there are little different.
Arguing with an inspector is like wrestling a pig in the mud, pretty soon you realize the pig enjoys it.
Old 05-13-2008, 10:01 PM
Thanks guys.
Similar Threads
Minimum branch ckt requirement Wendell Swedberg Electrical Systems: Home Inspection and Commercial Inspection 7 04-30-2008 07:56 AM
No PIA requirement Richard Stanley Business Operations: Home Inspectors & Commercial Inspectors 49 09-21-2007 09:04 AM
Elbow support requirement Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 2 08-19-2007 04:06 PM
Receptacle-cook top clearence requirement. M Kelekci Electrical Systems: Home Inspection and Commercial Inspection 3 07-28-2007 10:26 PM
Height requirement for exterior box David Macy Electrical Systems: Home Inspection and Commercial Inspection 8 07-16-2007 03:56 PM
vB.Sponsors
Ad Management by RedTyger
