Old 05-17-2008, 06:28 PM
fritzkelly fritzkelly is offline
A/C Disconnect?
Would this count as a proper disconnect on a roof mounted heat pump? It is the only disconnect and you have to remove the front panel screws to access it.
United Infrared
Old 05-17-2008, 06:57 PM
James Duffin James Duffin is offline
Re: A/C Disconnect?
Since it is a service disconnect it looks ok to me.
Old 05-17-2008, 07:24 PM
Re: A/C Disconnect?
I doubt it. You have to stick your hand into the equipment with live power in order to turn the power off. I'd write it up as un-safe.
I'll see if I can find something in the NEC and post.
Markus Keller
Old 05-17-2008, 08:36 PM
Randy Clayton Randy Clayton is offline
Re: A/C Disconnect?
No a electrical disconnect needs to be outside of the unit
Old 05-18-2008, 08:31 AM
Re: A/C Disconnect?
James, I'm looking in the NEC haven't found anything applicable yet.
Markus Keller
  #6 (permalink)
Old 05-18-2008, 09:26 AM
Re: A/C Disconnect?
James, I looked under NEC 08 424, 430, 665 and various other portions of text. I can't actually find anything that disallows that disconnect based on location.
I guess you're right about this one, unless of course ECJ shows up with his crystal ball of knowledge.
Markus Keller
  #7 (permalink)
Old 05-18-2008, 11:36 AM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Re: A/C Disconnect?
05 NEC 440.14 Disconnect cannot be mounted on access panels. Disconnect in line of sight.
IRC06 T40001.5 & 40001.5.
Billy J. Stephens HI Service
  #8 (permalink)
Old 05-18-2008, 05:55 PM
Jerry Peck's Avatar
Re: A/C Disconnect?
Quote:
Originally Posted by Fritz Kelly View Post
Would this count as a proper disconnect on a roof mounted heat pump?Attachment 6272
No.
It needs to be separate from the unit.
How many residential a/c condenser or heat pump units have you seen which do not have all panels removable for servicing?
On large commercial units, there typically is a large frame, with some panels removable, some not, and the disconnect could be mounted on the large frame or on a non-removable panel.
  #9 (permalink)
Old 05-19-2008, 08:07 AM
Robert Dalga's Avatar
Robert Dalga Robert Dalga is offline
Re: A/C Disconnect?
No, obviously not. What if you needed to replace the unit (you would have to kill the power from the main, then disconnect the lines and remove the unit...leaving improperly terminated conductors exposed (so you would then have to install a proper disconnect).
RJDalga
http://homeanalysts.com
Kalamazoo, MI
IC Home Inspection Report Writing
Similar Threads
disconnect box Clay White Electrical Systems: Home Inspection and Commercial Inspection 4 10-14-2007 06:20 PM
A/C Disconnect boxe: Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 6 09-30-2007 07:57 AM
A/C Service Disconnect Chris Skoczylas Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 19 08-27-2007 12:19 PM
AHU disconnect Jerry Peck Electrical Systems: Home Inspection and Commercial Inspection 5 05-16-2007 08:34 AM
a/c disconnect Martin lehman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 6 04-04-2007 12:48 AM
vB.Sponsors
Ad Management by RedTyger
