06-24-2008, 09:35 PM
K & B and insulation
Found this while strolling in an attic this morning. went straight down and turned the power off and called the realtor. luckily the house is vacant. The wire insulation was also missing in several places and it was all hot and hot  Never a dull moment
Tony
06-24-2008, 10:18 PM
Re: K & B and insulation
K&B? Is that short for "knob & bube" or "ken & bob"?
The apostrophe troll.
06-25-2008, 04:27 AM
Hey Tony, do you mind if I use those pics?
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
06-25-2008, 05:18 AM
Be my guest. Sure can get a point across.
Tony
06-25-2008, 05:22 AM
I guess I must have had my mind on food.... theres a K&B cafeteria that I ate at yesterday.
06-25-2008, 08:12 AM
Is the discoloration of the attic insulation 1) bleed-out of material from the wiring's insulation, 2) discoloration as a result of overheating, or 3) something else?
BTW, the condition of that particular section of wiring aside, the issue of knob and tub in insulated spaces is a bit more complicated that you might expect (or than I expected, anyway):
http://paragoninspects.com/pdf/elect...eandtheNEC.pdf
http://paragoninspects.com/pdf/elect...bewir ing.pdf
06-25-2008, 09:03 AM
Actually it's pretty simple, replace it
06-25-2008, 11:26 AM
[quote=Michael Thomas;47830]Is the discoloration of the attic insulation 1) bleed-out of material from the wiring's insulation, 2) discoloration as a result of overheating, or 3) something else?
It was from over heating......
06-25-2008, 11:32 AM
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Is this insulation? |
Rick Burkman |
Attic Areas: Home Inspection and Commercial Inspection |
5 |
06-18-2008 06:30 AM |
| SPF insulation |
Frank Bombardiere |
5 |
05-25-2008 06:09 PM |
| wet insulation |
dan orourke |
4 |
06-24-2007 10:19 AM |
| Insulation |
John Stephenson |
5 |
05-17-2007 05:14 PM |
| Insulation type |
Jeff Eastman |
6 |
04-07-2007 09:47 AM |
Ad Management by
RedTyger
