Old 07-07-2008, 05:08 PM
Dave Mortensen Dave Mortensen is offline
Homebuilt electric...again...
Homeowner switched out the 220 breaker, adding the 110 breaker and a nice block of wood to fill the gap left behind. I thought it was for an electric to gas stove replacement, but the electric range was still installed and siliconed to the countertop. So I didn't have access behind it. Now I'm wondering where the aluminum wire runs to, probably a 110 volt outlet somewhere. Leaving it to a capable sparkie to figure out, but I thought the wood block was a nice feature.
Similar Threads
electric eye height wayne soper Exterior Systems: Home Inspection and Commercial Inspection 10 06-10-2008 10:39 AM
Electric baseboard placement Reis Pearson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 3 04-09-2008 07:52 PM
Electric next to gas regulator Kevin Luce Plumbing System: Home Inspection and Commercial Inspection 4 10-03-2007 08:00 PM
electric water heaters Larry Moyer Introductions By New Members 2 08-13-2007 07:03 PM
Electric water heater dan orourke Plumbing System: Home Inspection and Commercial Inspection 14 07-18-2007 06:18 PM
vB.Sponsors
Ad Management by RedTyger
