Old 07-10-2008, 02:17 PM
Outdoor sump pump GFI?
Sump pump would indicate it's not required if in a basement or crawl space but exterior outlet should be GFI.
Does the sump pump exclusion from GFI protection apply to an outdoor outlet?
Old 07-10-2008, 02:56 PM
Re: Outdoor sump pump GFCI?
Matt,
Sump pumps are not excluded in the basement or crawlspaces either, since 2005.
Yes, the sump pump requires GFCI protection outdoors too.
GFCI chart available here: Construction and Litigation Consultants
Old 07-10-2008, 03:28 PM
Re: Outdoor sump pump GFI?
Thanks JP... I was looking at your chart but just didn't read down far enough
Similar Threads
Here's where you plug in the sump pump Eric Laney Electrical Systems: Home Inspection and Commercial Inspection 1 04-25-2008 06:21 PM
103 Degree Water in Sump Pit Nick Ostrowski Sub-Structure: Home Inspection and Commercial Inspection 12 01-25-2008 03:43 PM
Outdoor fireplace Jeff Eastman Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 15 06-06-2007 09:20 AM
Outdoor ceiling Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 2 06-03-2007 07:34 PM
Free Outdoor Grills Bruce Breedlove General Chit Chat: Home Inspectors & Commercial Inspectors 4 04-14-2007 12:05 AM
vB.Sponsors
Ad Management by RedTyger
