Old 07-17-2008, 02:03 PM
Richard Roshak Richard Roshak is online now
Exhaust fan is shower
Are powered exhaust fans permitted in ceilings of showers. This one was not even GFI protected.
Rich
Old 07-17-2008, 03:34 PM
Re: Exhaust fan is shower
Only if it is wet location rated, which is highly unlikely.
Most shower fans I've seen are simply grilles with exhaust duct leading to a remotely mounted exhaust fan.
Old 07-17-2008, 03:40 PM
Wet rated or not I have seen dips just in dryer vent lines running through the attic to a side wall that was not sealed and the water gathered at the dip and slowly destroyed the ceiling below. All that water from a shower (it has to be buckets) blowing thru a vent line I cannot see it not just running back down out of the vent to the shower unless it has a 427 hooked up to the fan.
Ted Menelly
"Castle"
Home Inspection Services
Old 07-18-2008, 04:48 AM
Jim Zborowski Jim Zborowski is offline
Ted, I really don't think you'ld want a 427 hooked to the exhaust fan with the price of gas right now.........maybe a small block?
Old 07-18-2008, 06:15 AM
paul hardy paul hardy is offline
that appears to be an older model broan fan/light the specs for those fans allow it if gfci protected. Fan/Light
Model 657
• 70 CFM 4.0 Sones.
• Designer styled white polymeric grille complements virtually any decor.
• Bright 100-watt light capacity.
Bulb not included
• 15-amp circuit acceptable.
• Type IC (Insulation Contact).
• Use with Model 68W or 68V two-function control (available separately).
• UL Listed for use over bathtubs and showers when connected to GFCI-protected branch circuit.
• Does not include heater.
  #6 (permalink)
Old 07-19-2008, 09:18 PM
Mark Jones's Avatar
Mark Jones Mark Jones is offline
I concur with Paul and Jerry. The exhaust fan units I've seen rated for use in a shower have an all plastic housing, or are required to be connected through a GFCI protected circuit.
Home inspection
Similar Threads
Warehouse Shower Rick Hurst General Chit Chat: Home Inspectors & Commercial Inspectors 2 07-04-2008 08:05 AM
Shower doors required? Scott Dana Building Interior: Home Inspection and Commercial Inspection 4 03-12-2008 07:59 AM
Hot Shower Donald Merritt Electrical Systems: Home Inspection and Commercial Inspection 8 02-17-2008 06:39 AM
Shower for Little People Joseph P. Hagarty Plumbing System: Home Inspection and Commercial Inspection 5 06-10-2007 07:17 AM
Shower stall floor Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 18 06-01-2007 09:41 PM
vB.Sponsors
Ad Management by RedTyger
