Old 07-29-2008, 05:39 PM
Ross Neag Ross Neag is offline
Condo elec SERVICE
On a condo panel that has NO MAIN, is it service or a subpanel (50 unit bldg)? Main service closet was unavailable for entrance. Reason asking is ground and neutral were on same bus.
IC Home Inspection Report Writing
Old 07-29-2008, 06:17 PM
John Arnold John Arnold is offline
Re: Condo elec SERVICE
Quote:
Ross - Most of the condo panels I see have no main, and often have no visible equipment grounds because they are not the service equipment panels (for god's sake, man, don't say subpanel around here!). So, most likely, the equipment grounds and the neutrals should be separated. The closet with the service equipment really should be accessible for the inspection. You want to be able to show the buyer where the main is, assuming there is one.
Old 07-29-2008, 06:49 PM
Jerry Peck's Avatar
Neither.
It is not the service panel, nor is it a "subpanel" as there is no such thing.
It is a "distribution panel", or, if it is easier to remember, it is "not service equipment".
Why? Locked? No one knew where it was?
Being as it is "not service equipment", the neutral is to be isolated from ground.
How do I *know* it is "not service equipment"? Because it is *one building* and *one building* does not allow for each of 50 units to have "service equipment" in them.
Old 07-29-2008, 08:42 PM
Jerry
A book says there is no sub panel or doesn't mention it or acknowledge it............and??????
The *terminology* sub panel has been in use for all of my living years and yours and everyone else alive.
Not looking for an argument by any means.
Sub Panel exists. It is just hiding from you because he knows you does not like it
Ted Menelly
Castle Home Inspection Services
www.inspectmycastle.com
Old 07-29-2008, 10:33 PM
Brandon Chew Brandon Chew is offline
You'll find sub panels on submarines. You won't find them in the NEC or the IRC.
  #6 (permalink)
Old 07-30-2008, 07:11 AM
You may want to consider mentioning to the agent ahead of time that you want to see the meter room, it cuts down on the excuses. I always want to see it to take a look and show the client where it is also.
Chicago code varies a bit depending on circumstances. Essentially, if the disconnect is in the meter room then owners/tenants have to have access to it.
If there is an onsite full-time engineer or it has exterior access only then it's a little different. Usually around here though it's in the basement, which means owners need access.
Markus Keller
  #7 (permalink)
Old 07-30-2008, 08:27 AM
Jerry Peck's Avatar
Marcus,
That's also in the NEC.
FREA Home Inspector Insurance
Similar Threads
Seperate service to outbuilding serves circuits in main building with own service ... Michael Thomas Electrical Systems: Home Inspection and Commercial Inspection 3 02-17-2008 07:44 AM
Condo Inspections David Banks General Chit Chat: Home Inspectors & Commercial Inspectors 5 11-02-2007 06:46 AM
Elec box questions Rick Maday Electrical Systems: Home Inspection and Commercial Inspection 3 09-08-2007 11:30 AM
Service conduit bonding at service equipment Michael Thomas Electrical Systems: Home Inspection and Commercial Inspection 0 08-07-2007 06:59 AM
condo panel box william siegel Electrical Systems: Home Inspection and Commercial Inspection 10 04-26-2007 08:40 AM
vB.Sponsors
Ad Management by RedTyger
