Old 05-08-2007, 06:23 PM
Jack Feldmann's Avatar
Jack Feldmann Jack Feldmann is online now
Outlet just outside it's life
From today's inspection
Old 05-08-2007, 06:47 PM
Victor DaGraca's Avatar
Victor DaGraca Victor DaGraca is offline
Re: Outlet just outside it's life
Was it still "functioning as intended"?
Old 05-08-2007, 06:48 PM
Did it test grounded or not????
Old 05-08-2007, 07:12 PM
Bob White's Avatar
Bob White Bob White is offline
Just needs some "Great Stuff" and duct tape.
Bob White
www.abide-able.com
Old 05-08-2007, 07:20 PM
Thom Walker's Avatar
Do you paint the duct tape?
- Paul Fix
  #6 (permalink)
Old 05-08-2007, 07:29 PM
Tim Moreira's Avatar
Tim Moreira Tim Moreira is offline
It's upside down.
  #7 (permalink)
Old 05-09-2007, 05:23 AM
Was not grounded. Actually the conduit was rusted thru and disconnected in another area.
No, I don't think it was "functioning as intended"
JF
  #8 (permalink)
Old 05-09-2007, 05:39 AM
John Arnold John Arnold is online now
But it was "rusting as intended". You're so picky.
  #9 (permalink)
Old 05-09-2007, 06:30 AM
Tim,
It's right side up.
- Paul Fix
  #10 (permalink)
Old 05-09-2007, 07:24 AM
Quote:
Originally Posted by Tim Moreira View Post
It's upside down.
Quote:
Originally Posted by Thom Walker View Post
Tim,
It's right side up.
Actually ... it's "either side up".
Neither is incorrect.
It is 'not typical' as the ground is 'typically' installed down.
  #11 (permalink)
Old 05-09-2007, 08:49 AM
I didn't say it was incorrect. I said it was right side up. I'm sick and tired of all you "electrician types" always putting the ground down. It's like it's beneath you or something.
We here at NOGUTS (National Organization of Grounds Up Top of Slots) have had enough of your alleged "convention." Our illustrators have permeated your nefarious publications and are changing the pictorials as we speak. We have members inside the NCE elite. Coed Check has already be reeducated. Your fancy-schmancy "convention" is doomed.
Rise up Ground, Rise up!
[If you'd like to become a certified member of NOGUTS, send your application, along with your credit card, pin#, and SASE to me. I'll send you a test booklet (one question, two hour time limit, self proctored) and an answer sheet so you can check yourself when you're finished. A certification certificate will be enclosed. Do not use it if you don't pass the test.]
- Paul Fix
  #12 (permalink)
Old 05-09-2007, 11:07 AM
It's upside down.
Tim,
It's right side up.
  #13 (permalink)
Old 05-09-2007, 05:27 PM
Lou Collier Lou Collier is offline
Actually, there is a good reason to install the ground hole up. All of the outlets in my house are installed that way.
  #14 (permalink)
Old 05-09-2007, 05:43 PM
Rick Hurst's Avatar
Same here Lou.
I actually heard at a seminar that NEC was wanting them to be installed with the ground on the top in 2008 or 09.
  #15 (permalink)
Old 05-09-2007, 06:48 PM
There is a better reason to install them with the ground down.
This debate has been going on since the addition of that third prong ... ground on top or on the bottom, people give good reasons for both, but I buy the one with the ground down better.
  #16 (permalink)
Old 05-09-2007, 07:07 PM
[quote=Thom Walker;5014]Coed Check has already be reeducated. Your fancy-schmancy "convention" is doomed.
Can I join that "coed check" organization?
  #17 (permalink)
Old 05-09-2007, 07:54 PM
Quote:
I prefer them with the ground down, however at the hospital I work at I have seen may a times where the outlet was installed ground down with a metal cover plate. (Almost all of the plates are metal, not my call)
Don't ask me how or why, but, when the center screw backs it's self out and falls to the ground, (this happens more than you might think) and then the next unsuspecting person comes along and goes to plug something in and they bump the outlet as they insert the plug, BOOOOOOM. The metal cover plate falls across the hot and neutral and scares the crap out of the person doing it and trips the breaker.
If the ground was up, that would not happen.
Not good in a patients room.
  #18 (permalink)
Old 05-09-2007, 08:30 PM
[quote=Victor DaGraca;5061]
Send your credit card and pin# and you can. Hell, I'll throw in lifetime membership in the NCE with it. But a prerequisite is NOGUTS certification.
- Paul Fix
  #19 (permalink)
Old 05-09-2007, 08:50 PM
Not sure I would say it is a "better" reason. A "different" reason, perhaps.
  #20 (permalink)
Old 05-09-2007, 08:53 PM
Tim, just wondered why you say you prefer the ground down when you have first hand experience with the hazards of installing the outlet so the prongs can short out?
  #21 (permalink)
Old 05-09-2007, 09:01 PM
