Old 05-10-2007, 04:41 AM
Jim McClendon Jim McClendon is offline
Service panel question
Has anyone seen the grounds twisted together like this and is it ok? Why do it?
HomeGauge Reports
Old 05-10-2007, 06:27 AM
Jerry Peck's Avatar
Re: Service panel question
Quote:
Yes, many times, and it is still and always wrong.
Why? To save putting them into their own holes? It took a lot longer to twist them together than it would have to just have put each (or even two if allowed) into their own terminals.
'Hey, Bubba, lookee here, I just made me a stranded wire, looks neat,huh?'
Old 05-10-2007, 06:40 AM
Thanks Jerry.
Old 05-20-2007, 12:57 PM
Why is it still and always wrong? I cant find any information about it.
Old 05-20-2007, 07:46 PM
Bob Mayer Bob Mayer is offline
I cannot find where the NEC prohibits this, but I would guess that the panelboard (or terminal bar) manufacturer prohibits it. Remember everything has to be installed in conformace the NEC and with the manufacturer's instructions. See this post Multiple neutrals under same lug,
the whole thread is useful.
- BOB
  #6 (permalink)
Old 05-20-2007, 08:01 PM
Scott Patterson's Avatar
It has to do with the conductors making the proper contact. If they are all bunched up together, some will be loose and may not make proper contact. Also the bending and twisting will weaken the wire to a point that they could break. I believe it is also on the panels schematics and it can be found in the codes.
Scott Patterson
  #7 (permalink)
Old 05-20-2007, 08:45 PM
James Duffin James Duffin is offline
It is wrong because the terminal is not rated for the number of wires plus if you ever have to service a circuit wrapped up in the twisted mess it would involve unwrapping the whole bundle. I would write it up for the reason I stated but it would never be addressed I feel sure.
  #8 (permalink)
Old 05-20-2007, 09:41 PM
Mike Huppi Mike Huppi is offline
Yea but it looks cool dont ya think
  #9 (permalink)
Old 05-20-2007, 10:22 PM
Thom Walker's Avatar
Jim,
Is this helpful? Ignore the title. Read the whole thing for rationale.
- Paul Fix
  #10 (permalink)
Old 05-21-2007, 07:28 AM
Thanks for the replies. The terminal is rated for 3 wires. The licensed electrician said they twisted the wires for better continuity. I was wondering... your thoughts?
  #11 (permalink)
Old 05-21-2007, 09:15 AM
I count 20 circuits. It looks as if there are two single grounding conductors at the bottom of the grounding bar. This leaves 18 grounding conductors in four bundles, more than the three conductors per bundle for which you say the terminals in the ground bar are rated. If it violates the manufacturer's instructions, it fails the inspection and should be repaired. Whether it has "better continuity" or not is irrelevant. There is a saying in the Free Software arena: "With many eyes, all bugs are shallow." The NEC has been subject to many eyes for over 100 years. Deviations from it in this panel are not subject to "many eyes," but are subject to the boost that Murphy's Law gives to unintended side effects. I do not mean to go on and on (I do not think that I do ), but it bothers me when someone, especially a licensed someone, say that he or she knows better than the code or the manufacturer's requirements.
Quote:
I have worked on panelboards with long lengths of twisted grounding conductors similar to those in the photograph and James is right. The only safety aspect of such a situation is that I shut off the main breaker for a job for which I might not otherwise. Untwisting all the conductors is a pain, and after they are untwisted they are a real mess, I spend more time trying to straighten them out than I did untwisting them.
- BOB
  #12 (permalink)
Old 05-21-2007, 03:01 PM
Thanks Bob, I appreciate the detail.
  #13 (permalink)
Old 05-21-2007, 06:19 PM
Jerry Peck's Avatar
DO NOT twist them.
They will have a better connection laying on each other than being twisted (unless you can duplicate the twist and laying together of the machine done stranded wire, but I doubt you will find '3 strand stranded wire', so that's pretty much out of the question.
Home inspection - The Cost Of Business.
Similar Threads
Electrical service box located in closet Kevin Luce Electrical Systems: Home Inspection and Commercial Inspection 17 05-28-2008 08:40 PM
Wire splices in service equipment panel Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 13 12-10-2007 01:22 PM
Service Mask Head under Eaves K Robertson Electrical Systems: Home Inspection and Commercial Inspection 13 05-06-2007 07:22 AM
16 guage wire in service panel Eric Shuman Electrical Systems: Home Inspection and Commercial Inspection 5 05-03-2007 01:11 PM
Welcome From F.I.R.E. Service Dale W. Feb Introductions By New Members 0 04-04-2007 06:22 PM
vB.Sponsors
Ad Management by RedTyger
