Results 1 to 2 of 2
    Default Vinyl Floor Inspection in Mathiston, MS 39752
    We have an immediate need for an inspector to inspect a vinyl floor in a residential home in Mathiston, MS 39752.
    The complaint is for shrinking vinyl. You are required to have a moisture meter. Temperature and humidity readings required along with pictures.
    Payment will be made within 10 days of completion of the inspection or immediately after the inspection if you accept bankcards.
    You are responsible for setting the appointment. The inspection report must be submitted on our website within 48 hours of the inspection.
    Inspect Solutions, Inc. has been contracted to provide national inspection services for major retailers and manufacturers.
    Our clients are major retailers or manufacturers that just want to know what is wrong so the problem can be taken care of. They also need our opinion so the proper party can be charged back. For example, if it is a major box store inspection and it is an installation related issue, our reports are used for the reason of the chargeback to the installer.
    We have our own secure-web based program that you will upload the photos. You will also complete the report online. Our web-based program is extremely easy.
    Contact Ron Gould via email at rgould@inspectsolutions.com or (888) 854-0946.
    Default Re: Vinyl Floor Inspection in Mathiston, MS 39752
    We ended up getting this job covered.
