Results 1 to 1 of 1
    Default Floor Inspection-Appleton, MN
    We have an immediate need for an inspector to inspect a vinyl tile floor in Appleton, MN, 56208. We need to have this performed before Monday, August 20th.
    The complaint is for tiles lifting. Checklist/directions for the inspection will be provided. Inspector must have a non-invasive moisture meter (Tramex, Delmhorst, Protimeter, etc. picture of the meter on the floor will be required). UV light is a plus (to check for tracers in the adhesive), but not required. No destructive testing involved. Installers will have removed one or two tiles for pictures of the adhesive and measurements of the trowel marks. Inspection time should be 10-15 minutes.
    Payment will be made within 10 days of completion of the inspection
    You are responsible for setting the appointment. The inspection report must be submitted on our website within 48 hours of the inspection.
    Inspect Solutions, Inc. has been contracted to provide national inspection services for major retailers and manufacturers.
    Our clients are major retailers or manufacturers that just want to know what is wrong so the problem can be taken care of. They also need our opinion so the proper party can be charged back. For example, if it is a major box store inspection and it is an installation related issue, our reports are used for the reason of the chargeback to the installer.
    We have our own secure-web based program that you will upload the photos. You will also complete the report online. Our web-based program is extremely easy.
    Contact Ron Gould via email at rgould@inspectsolutions.com or (888) 854-0946.
    Inspect Solutions
