Results 1 to 1 of 1
10-26-2007, 01:26 PM #1
Wood Floor Inspection, Eagle Mtn, UT 84043
We have an immediate need for an inspector to inspect a wood floor in Eagle Mtn, UT 84043.
The complaint is for chipping and peeling in an entry way. You are required to have a moisture meter (non-invasive will work and a pin meter). Temperature and humidity readings required along with pictures.
Payment will be made within 10 days of completion of the inspection
You are responsible for setting the appointment. The inspection report must be submitted on our website within 48 hours of the inspection.
Inspect Solutions, Inc. has been contracted to provide national inspection services for major retailers and manufacturers.
Our clients are major retailers or manufacturers that just want to know what is wrong so the problem can be taken care of. They also need our opinion so the proper party can be charged back. For example, if it is a major box store inspection and it is an installation related issue, our reports are used for the reason of the chargeback to the installer.
We have our own secure-web based program that you will upload the photos. You will also complete the report online. Our web-based program is extremely easy.
Contact Ron Gould via email at rgould@inspectsolutions.com or (888) 854-0946.
Inspect Solutions
