Old 05-04-2009, 10:56 PM
daniel nantell daniel nantell is offline
deck post in contact with ground
I wrote up a deck with the post in contact with ground , I wrote it up as not a recommend practice, should maintain clearance between ground and support post, the builder told the owners that he used treated wood and I was ok to sink post in ground. My expercience is even through its treated when it in the ground for a few years it still begins to rot.
dmn
United Infrared
Old 05-04-2009, 11:23 PM
Gunnar Alquist's Avatar
Re: deck post in contact with ground
dmn,
I have a couple of questions.
First of all, what chemical was it treated with? If it is "ground contact" pressure treated lumber, my understanding is that it should last for decades without significant decay. Around here, ACZA (very dark green, almost black colored) treated lumber can be used in direct and prolonged contact with soil. However, if it is the lighter green or reddish, probably not.
Another question, is what is the post resting on? If there is no concrete footing or pier block, then what is holding up the deck? If the post is sunk into the soil, then it is more likely to sink/settle.
We have enough youth, how about a fountain of Smart?
Old 05-05-2009, 04:23 AM
Nick Ostrowski Nick Ostrowski is online now
Maybe the the builder would like to put that in writing for the owners.
Old 05-05-2009, 04:36 AM
A.D. Miller's Avatar
A.D. Miller A.D. Miller is offline
Quote:
DN: It seems that this is what the IRC thinks it should look like:
"What the plainspoken man lacks in subtlety he makes up in clarity." - A.D. Miller
www.texasinspector.com
Old 05-05-2009, 08:26 AM
Jerry Peck's Avatar
Wood posts CAN be in ground contact:
- R319.1.2 Ground contact. All wood in contact with the ground, embedded in concrete in direct contact with the ground or embedded in concrete exposed to the weather that supports permanent structures intended for human occupancy shall be approved pressure-preservative-treated wood suitable for ground contact use, except untreated wood may be used where entirely below groundwater level or continuously submerged in fresh water.
That said, a post in ground contact STILL requires a proper footing and anchoring to the footing.
This is from the American Wood Council, their Design for Code Acceptance 6, Prescriptive Residential Deck Construction Guide: http://www.awc.org/Publications/DCA/DCA6/DCA6.pdf
Scroll down to the Figure 12 on the bottom of page 9.
Have the builder provide documentation that the treatment of the wood posts meets or exceeds that which is required for ground contact and burial.
  #6 (permalink)
Old 05-05-2009, 11:18 AM
Like these from this morning's inspection? .40 CCA pressure-treated is all that is required, and that is what they are. Labels were still stapled to the tops. These are just 12 years old.
Why do it?
  #7 (permalink)
Old 05-05-2009, 02:41 PM
John Dirks Jr's Avatar
John Dirks Jr John Dirks Jr is offline
When they are 4x4's I pay more attention to them. With 6x6's there is much more material so it is less of an issue.
I look at each situation on a case by case basis.
John Dirks Jr - Arundel Home Inspection LLC
Maryland Home Inspection - Maryland Home Inspectors - Maryland Radon Testing - Baltimore County Rental Inspection
  #8 (permalink)
Old 05-11-2009, 09:26 AM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
A.D.
I don't get the 3rd diagram that shows toe nailing the beam/post connection.
I don't think that toe nailing is recognized as a positive connection.
Eric Barker
Barrington, IL
  #9 (permalink)
Old 05-11-2009, 10:27 AM
Quote:
Originally Posted by Eric Barker View Post
A.D.
EB: You'll have to contact the ICC. It is directly from the 2006 IRC, which I did not write.
  #10 (permalink)
Old 05-11-2009, 03:16 PM
One of the above post showed x4 post rotten off in 12 years, that has been my expierence, they say its treated and will last 20 years but Ive had them completely destroyed in 10 years, mabe the treating manufacture did a poor job pressure treating the lumber, that why I think its better building practice to keep the wood off the ground, even pressure treated. thanks
dmn
  #11 (permalink)
Old 05-11-2009, 03:57 PM
John Goad John Goad is online now
Treated Wood Alert
Clarksville Home Inspection
JW Goad
  #12 (permalink)
Old 05-11-2009, 07:46 PM
Michael Greenwalt's Avatar
Michael Greenwalt Michael Greenwalt is offline
The issue with treated lumber in contact with the ground doesn't have as much to do with the decay of the wood which is eventually an issue with any lumber product and cannot be avoided. The issue lies in the action between the house, the deck and the ground.
Depending on the area which you live, and the type of soil you have, there is movement.
Take for instance the area which I live, Kansas. We have a freeze/thaw cycle that is serious enough to cause upheaval at ground level. If our decks support columns were not secured to a footing, below frost level, the column would rise with the ground which would then translate that movement to the deck ledger board attached to the house. Do that repeatedly and you have recipe for disaster from the ledger bolts working away from the house rim joist.
The 2006 IRC has some additional requirements for deck support column footings depending on the span of the deck joists, soil composition and frost line depth.
Bottom line would be depending on the soil composition of your area, your freeze/thaw cycle, footing requirements and local jurisdiction. Here, footings are required to extend 36" below ground (our frost line requirement) for house footings, and deck footings.
If I had two faces, would I be wearing this one?
Abraham Lincoln
  #13 (permalink)
Old 05-11-2009, 08:13 PM
Jerry Peck's Avatar
The IRC states that, *IF* the deck is attached to the house in any way, shape or form, the foundations for the deck must be below frost depth just like those of the house it is attached to, HOWEVER ... *IF* the deck is a free standing deck and not attached to the house in any way, shape or form, then the deck does not require footings to be below frost level, the deck is free to rise and fall on it own, not being tied to the house in any way.
  #14 (permalink)
Old 05-11-2009, 08:53 PM
mathew stouffer mathew stouffer is offline
except untreated wood may be used where entirely below groundwater level. I am confused, which is easy to do, but what does this mean
  #15 (permalink)
Old 05-11-2009, 09:11 PM
Vern Heiler's Avatar
Vern Heiler Vern Heiler is online now
Quote:
I believe bacteria need more oxygen than is in most water. I know that the stumps in the bottom of Lake Norman are very sound! I've tried to knock a few of them out with a lead keel and the stump never wiggled.
  #16 (permalink)
Old 05-23-2009, 10:59 AM
I saw this deck last week. Eight of the nine suport posts that were beneath grade level had varying degrees of rot and deterioration. The second pic here shows how much the deck was dropping at the outside edge.
  #17 (permalink)
Old 05-23-2009, 11:12 AM
Rick Hurst's Avatar
Nick
Thats defeats all the talk that PT post don't decay now doesn't it?
  #18 (permalink)
Old 05-23-2009, 12:00 PM
Jerry Peck's Avatar
Quote:
Rick,
All depends on what it is treated with and what it is treated for.
  #19 (permalink)
Old 05-30-2009, 07:20 PM
6x6 from yesterday.
  #20 (permalink)
Old 05-30-2009, 09:02 PM
Good find John , I guess they thought that putting rocks at top of 6x6 would prevent rot. If its in the ground its going to rot eventually and usually before the 20 years warranty expires.
dmn
  #21 (permalink)
Old 05-30-2009, 09:23 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Quote:
Originally Posted by John Dirks Jr View Post
6x6 from yesterday.
Might want to consider leaving that Ring in the Truck.
* could be a safety Issue ( climbing around & getting snagged on an exposed nail head. )
Billy J. Stephens HI Service
Similar Threads
Post at grade, footing flush w/ground Matt Fellman Structural Components: Home Inspection and Commercial Inspection 3 02-13-2009 09:29 PM
Do you ever contact sellers directly about issues? Brian Thomas InspectionBlues: Home Inspectors & Commercial Inspectors 15 08-25-2008 06:00 PM
Post Your Problems: Inspect home inspector's credentials - Pittsburgh Post Gazette Brian Hannigan Associations, Ethics, Standards, Licensing, Legislation:Home Inspectors & Commercial Inspectors 0 08-06-2008 12:11 AM
Wood contact Jim Gecz Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 8 03-10-2008 08:46 PM
WH Flue in Contact with Drywall Rick Hurst Plumbing System: Home Inspection and Commercial Inspection 5 10-17-2007 08:46 PM
vB.Sponsors
Ad Management by RedTyger
