Results 1 to 15 of 15
Thread: another 1027 question
05-26-2010, 08:04 PM #1
The 1027 will take 90 incremental measurements. What happens if you run it longer than the 90 limit? Will it continue on and just ditch the oldest measurement for each new one or cease to record any new data?
05-27-2010, 11:24 AM #2
Re: another 1027 question
Ditches the old, and in with the new.
Paul Kondzich
Ft. Myers, FL.
05-27-2010, 01:09 PM #3
Don't think so. Take a look at the top of Page 9 in the 1027 manual where it says:
"NOTE: ...The interval storage stops updating after 90 intervals until the next memory clear."
Might be a good idea to go get a copy: Sun Nuclear - Your Most Valuable QA & Dosimetry Tools
05-27-2010, 01:29 PM #4
Hmmm, well all I know is that when I had mine I left it on im my house for about a week. The avg. kept changing so I would assume it was still monitoring.
Paul Kondzich
Ft. Myers, FL.
05-28-2010, 03:24 AM #5
The running average is maintained for however long you run it. The data logging is only good for 90 hours.
Stu, Fredericksburg VA
05-28-2010, 03:22 PM #6
90 hours or 90 data points? I am not very familiar with the 1027 (I have a 1029) but I am wondering if you can adjust the interval the 1027 records data.
On the 1029 (which can store 999 data points) you can set the interval between data points to whatever you wish - 1/2 hour, 1 hour, 2 hours, 4 hours, 8 hours, 12 hours, 16 hours, 20 hours or 24 hours. With an interval of 1 hour (which I use almost exclusively) I can run a radon test for 41 days 15 hours before the memory is full.
Bruce Breedlove
www.avaloninspection.com
05-28-2010, 03:27 PM #7
05-28-2010, 03:38 PM #8
Bruce Breedlove
05-29-2010, 03:20 AM #9
05-29-2010, 04:56 AM #10
The 1027 will measure 90 data points. The intervals can be changed. If you take the cover off, there are 4 pin switches on the circuit board. They can be set to 1, 4, 12 or 24 hour intervals.
If you want to measure within the EPA protocol using a single 1027 CRM, it must be set to 1 hours increments.
05-29-2010, 05:38 AM #11
05-29-2010, 09:35 AM #12
[QUOTE=John Dirks Jr;132468
If you want to measure within the EPA protocol using a single 1027 CRM, it must be set to 1 hours increments.[/QUOTE]
In NJ, the radon protocol is set by the NJDEP.
We can use 4 hr intervals; there also another little tidbit I won't get into but helps me out sometimes if I need a fast result...
NJ also allows a single canister.
05-29-2010, 11:22 AM #13
05-29-2010, 04:09 PM #14
You won't find documentation about a single canister either.
If you want the protocol, you'll have to call and request it.
In NJ you have to be 'certified' to deploy & retrieve any type of radon testing equipment for a real estate transaction.
After that, there has to be a licensed 'business' that will measure the amount of radon and issue a 'certified' report.
I used to be a licensed radon business but I got tried of paying the state all types of money, including $400 every 2 years so they could 'audit' me (basically come to my office and try to find what I did wrong so they could fine me and collect more money).
Here's the # 800- 648-0394.
I'm just curious, are you planning to do testing in NJ or you just think I'm making this up?
05-29-2010, 05:31 PM #15
