Results 1 to 9 of 9
Thread: Termite treatment
08-31-2010, 07:34 AM #1
Termite treatment
Is there a need for a termite treatment for a home with cmu exterior walls? It has wood interior walls.
08-31-2010, 07:36 AM #2
Re: Termite treatment
Absolutely.
Paul Kondzich
Ft. Myers, FL.
08-31-2010, 07:38 AM #3
Being that your in Georgia, the more of the reason to do so.
08-31-2010, 07:48 AM #4
08-31-2010, 04:52 PM #5
09-01-2010, 10:14 AM #6
Need it. The smallest imperfection, crack, void or breach in the envelope provides access to termites.
Termite tunnel up side of wall to reach a window or other break in the supposedly solid envelope has never been seen so why have treated in a state that has only lazy termites.
Forest Gump "Stupid is as stupid does."
11-07-2010, 04:29 PM #7
The lender involved would be the deciding factor in whether it is "required", however, if there is any evidence of any termite activity, treatment would be a good idea.
11-07-2010, 04:59 PM #8
I did an inspection a while ago on a metal framed home. There was a WDI done on the home with conducive conditions all around the home. When the lender balked the Realtor told the lender that it was a metal framed home and it was not necessary. The lender agreed, put it in his report and they wound up financing the home even with the stipulation that a termite report was necessary.
Go figure
11-07-2010, 08:05 PM #9
Depends who you ask. The reator doesnt care (wants commission). The mortgage company doesnt care (wants commission and will sell the note anyway).
Some houses get termites, other never do. Here in SE Florida all the home are supossed to be pre-treated for subterranean termites. Most of those treatements were done imporperly. Most people are not pro-active and will not treat until there is a visible problem.
