Results 1 to 30 of 30
Thread: what kind of poop
10-09-2011, 01:48 PM #1
what kind of poop
What kind of animal poop does this look like? It was found in the insulation of crawlspace near the sill plate. It's about 1/8 inch in diameter.
10-09-2011, 02:22 PM #2
Re: what kind of poop
Probably a rat, or it's close cousin.
10-09-2011, 03:10 PM #3
What does it taste like?
10-09-2011, 04:40 PM #4
10-09-2011, 05:08 PM #5
Just say rodent or critter when you report it.
10-09-2011, 05:43 PM #6
10-09-2011, 06:34 PM #7
Yes, I've actually used this more than once.
There's animal poop on the insulation in the crawl space. I'm not an animal poop expert so I don't know what kind of rodent it is. Consult a licensed pest control operator and take action as you and he agree would be best.
10-09-2011, 06:48 PM #8
John, if it looks like something a cat would drop, but with no attempt to bury it, my guess is racoon kaka. They will sometimes select one general area if they plan to stay a while.
For the record, squirrels drop a small round pellet.
10-10-2011, 05:30 AM #9
I can't believe no one has identified the 'droppings' correctly. Your 2nd photo of the water logged girder was the the clue needed. Fish poop. The fish pooped, the water level receded, end of story. The real estate agent should have listed the property as 'indoor seasonal pool.'
From your 2 pics, I'd say it looks like that house is in pretty crappy condition.
Curt Downs
Licensed HIC
CT
10-10-2011, 05:43 AM #10
The wet crawl and affected structural components are the result of poor site grading. This includes a ground level deck that blocks access for the ability to solve the problem. Oh yeah, gutters jam packed with leaves too. It's amazing how simple stuff is often neglected resulting in much bigger problems.
10-10-2011, 07:32 AM #11
Well… I don’t know nuthin’ bout poop, but that’s some nasty dry-rot or cellar rot you’ve got on those joists!
Cheers!
CaoimhÃ*n P. Connell
Forensic Industrial Hygienist
AMDG
10-10-2011, 09:58 AM #12
that's inspector poop, i was craweling around there last week
10-10-2011, 10:07 AM #13
Looks like bat doody..
10-10-2011, 06:36 PM #14
10-10-2011, 07:06 PM #15
My guess is it's reptilian or amphibian. Toad, frog, salamander, snake.
The white and dark indicates an animal that that excretes urine and feces together, bird or amphibian / reptile. I guess birds aren't too likely in a crawl.
Anyway, that's probably the least of their problems!
10-12-2011, 05:07 PM #16
Strangely enough, I have found bats in a crawl space before.
10-12-2011, 09:18 PM #17
Being that the droppings are pointed on the end, I would say it is what is known as a roof rat. If the droppings are blunt ended that would be a indicator of a Norway rat.
10-13-2011, 03:36 AM #18
Rick,
Is one of the locally trusted authorities when it comes to poop
10-14-2011, 02:45 AM #19
Barry, I don't think Rick is going to give out his address on that one cause he don't wanna get a lot of poop in the mail. lol...
10-27-2012, 06:13 PM #20
[QUOTE=John Kogel;179502]John, if it looks like something a cat would drop, but with no attempt to bury it, my guess is racoon kaka. They will sometimes select one general area if they plan to stay a while.
For the record, squirrels drop a small round pellet.[/QUOTE
Raccoon crap is almost as big as a turd from a medium sized dog. No self-respecting raccoon would drop something so small!
10-27-2012, 06:16 PM #21
When the client asks, "is it fresh?" I tell them to have the re-litter crunch a little between his/her teeth. If it's 'al dente' then it's old!
10-28-2012, 05:36 AM #22
Bats.
10-28-2012, 12:01 PM #23
Too Funny ! Now I'm convinced your last name was assigned by mental health care pros, as a derivation of Tourette Syndrome. Reading this thread I've decided the profession needs some polish in referencing what living creatures leave behind. As evidence, I submit poop, Kaka, droppings, Doody and more. In my bug man training I was taught frass was what insects leave, bigger mammals at least usually are referenced with scat andocaisionally dung and I'm assuming that can be stretched to smaller mammals. Last; when an H.I. is posting, it is premised by the word Bull
10-29-2012, 07:26 AM #24
Be careful to say "Bats". I know of someone that discovered bats in his attic (not in his belfry) and somehow, in his efforts to get them removed, the state and federal government got involved. It ended up with he couldn't get rid of them because of federal laws---if one died the best thing he could do was secretly get rid of it, or possible face a federal fine (read that big bucks) if they found it during an inspection. His home is on some kind of a federal register now, and someone comes around every so often to check on the bats. They told him the brood flies to a specific location in VA to winter, and comes back to summer at his house!
10-29-2012, 08:53 AM #25
10-29-2012, 07:47 PM #26
10-29-2012, 08:42 PM #27
10-29-2012, 09:56 PM #28
LOL Garry. I terminated the inspection in the crawlspace, it got worse the farther north I went, told the buyer I went farther than I normally do, but pulled the plug when I could no longer see the vapor barrier. 95% of the time I tell people that if I can't see 25-30ft in all directions, they need to call Clean-Crawls.com, then have me come back for an additional fee.
10-30-2012, 03:30 AM #29
Snake feces.
10-30-2012, 11:04 AM #30
Nice one, Jim. I can smell it from here.
PS, how was the Chantrelle mushroom? Tasty?
