Results 1 to 10 of 10
    Jun 2008
    Default critter burrow saves me
    Thanks to the critter burrow that prompted me to look closer under the porch. Otherwise I might have missed the abandoned UST. The fill and vent lines to the left in the first pic serve the newer tank that's in the basement.
    Default Re: critter burrow saves me
    Nice catch, John!
    What was the critter? That's too big a trench for a normal rat.
    Jun 2008
    Nice catch, John!
    Ya know, when I found the UST I totally lost interest in the critter.
    Judging from the size of the trench, probably a rabbit or maybe opossum. Too small for a raccoon or ground hog.
    Nice catch, John!
    Whistle pig is my guess. At least we know it's not the Norwegian Roof Beaver.
    Oct 2011
    Minneapolis, MN
    Wow, your ground hogs are bigger than opossums? Yikes.
    Opossums and raccoons don't dig burrows, though they may use those others have dug.
    Wood chuck? Oh, wait, that's the same as a ground hog, isn't it. They're more likely to dig around structures than rabbits, that's what I'd guess it is, even if it looks smallish.
    - James Burgh, 1754.
    Jun 2008
    Quote Originally Posted by Kristi Silber View Post
    Groundhogs get pretty hefty around here compared to opossum. Maybe slightly larger.
    Are you sure your not confusing them with the prairie dog which are more associated with the mid-west?
    John,
    why would you "not" always look closer? i came across a deck the other day vinyl siding to the ground. laying on top of the deck with a probe found it was rotted out. the flipper was as usual trying to hide it. whenever lattice, stored items or something else i always look, cya.
    steve
    Oct 2011
    Minneapolis, MN
    I know what prairie dogs look like, that's not what I mean. We have ground hogs and opossums (the latter only in the last decade or so, but they're moving north). I've seen both in my dad's suburban back yard. Ground hogs can be a major problem, sometimes digging vast burrows under buildings, and chewing on wood.
    Male ground hogs get up to about 10 lb., whereas Virginia opossums (the common opossum found in the US) can be up to 14 lb (male) or 8 lb (female). Ground hogs look bigger than they are because of their long, dense fur.
    Oct 2009
    michigan
    Be extra careful when rooting around in shaded areas like this.
    It has been my unfortunate experience to discover that the poison ones like to hide among other foliage.
    Also, when the leaves are gone in winter time the vines or branches are still there to share their urosol (sp?).
    Jun 2008
    Quote Originally Posted by Stephen Gaudet View Post
    John,
    steve
    Oh I'm very thorough, trust me. Although, sometimes it seems like a tap on my shoulder comes out of nowhere and says, "go look over there again"
    I'm sure any inspector who's been in the business any length of time knows the feeling.
