    Jun 2012
    Columbus, Ohio
    Default Radstar or Radalink...which should I use?
    I am in the market for a continuous radon monitor and would like to know which brand you all prefer?
    Matt Kiefer, Columbus Advanced Inspections
    Home Inspection Columbus Ohio
    Radon Testing Columbus Ohio
    Aug 2008
    Atlanta, GA
    Default Re: Radstar or Radalink...which should I use?
    I chose Sun Nuclear #1028's for several reasons including profitability. radon.sunnuclear.com
    I recently received a solicitation from another player: ALPHA IIĀ® Continuous Radon Monitor from Diversified Research Does anyone have one of these or have anything to say about the product or service?
    Nov 2009
    St Paul, MN
    Radalink is a service where you lease the monitor. At least it used to be when I used them. Radstar is a monitor that you purchase and run the test on your own. In the long run purchasing your own equipment is the way to go.
    I've been using the Radstar units 4 or 5 years and never has a problem with them.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Hands down Radalink. Call me personally and I will tell you why... 800-544-8156. Ask for Nathan.
