Thread: mold or????
    cory nystul's Avatar
    cory nystul Guest
    Default mold or????
    This is a sub floor i found today would you call this mold or?????
    Default Re: mold or????
    If dry now, I would call it water-stained from a past leak. If it is still wet, it's a leak. If there are fruiting bodies of mould that can be wiped with a finger, then I call it active mold growth.
    But there are places you are advised to say mold-like or some other wishy washy term unless you have a PhD in moldology.
    OSB takes 10 times longer than plywood to dry out. So that subfloor may need to be replaced if the moisture content is still over 20%.
    Did you check it with a moisture meter? Looks wet to me...
    For what it’s worth – I don’t see any mould.
    CaoimhÃ*n P. Connell
    PhD, Moldology
    Forensic Industrial Hygienist
    Forensic Applications Consulting Technologies, Inc. - Home
    AMDG
