Results 1 to 10 of 10
    Jul 2010
    Eatonville, WA
    Default One that got away?
    I really expected to see a dead rodent near this.
    I guess he is one that got away.
    (This picture is my own invasive inspection after we closed).
    F.I.R.E. Services
    Glenn Cummings
    Eatonville, WA.
    Default Re: One that got away?
    Where was the staple located?
    Jul 2010
    Eatonville, WA
    No staple on this romex, in this bay.
    Romex threaded through hole drilled in wall stud, within 12 inches of box.
    Seems to be the case in Mfg Home (at least this one).
    Glenn Cummings
    Eatonville, WA.
    Glenn...
    Quote Originally Posted by Glenn R Cummings View Post
    Just follow the trail of little poops... you'll find him.
    CP
    Quote Originally Posted by Caoimh*n P. Connell View Post
    Glenn...
    After an arc like that ... Start with the Big Pile of little poops.
    john stone's Avatar
    john stone Guest
    My cat dropped him with his 30.06 sniper rifle
    Mar 2014
    Ozark, Missouri
    In standard housing, cables through bored holes still must be stapled within 12" of a clamped box and within 8" of a clamp less box. The keywords are "securely fastened". NEC 2008 334.30(A) and 314.17 Exception. In Manufactured Housing, cables are only required to be secured at boxes, if they are #10 and smaller. NEC 545.4(B) Rodents, on the other hand, are not required to be secured at all.
    Feb 2010
    Wenatchee Wa
    Need AFCI/GFCI's to protect them little guys
    Don Hester
    NCW Home Inspections, LLC
    Quote Originally Posted by Don Hester View Post
    Don't even think that, PITA will lobby for it.
    Quote Originally Posted by john stone View Post
    Sweet!!
