Results 1 to 25 of 25
Thread: "Old House" odor
11-04-2014, 11:16 AM #1
"Old House" odor
To all my leaned Home Inspectors –
As you all know, often times an older house has an “Old House” odor. I don’t find the odor offensive, but some people don’t like it.
If the property is in excellent shape, and not scheduled for any renovations, is there a cost effective way to address the odor?
Caoimh*n P. Connell
Forensic Industrial Hygienist
Forensic Applications Consulting Technologies, Inc. - Home
AMDG
11-04-2014, 12:43 PM #2
Re: "Old House" odor
I have used OdoBan for many years. Available at Sams and other.
OdoBan® - Odor Eliminator - Home
11-04-2014, 12:45 PM #3
Well Caoimh*n - at first I was thinking this is a loaded question from you.
Seeing that you have so many labs and tests and years of experience behind you.
Exotic and dangerous and toxic is your realm, but ordinary smells are not in your knowledge base?
Interesting.
Good info from Kevin though. I think i'll check out their website for my own old house smell..
Thanks Kevin
...and thanks Caoimh*n for letting us know what you don't know
11-04-2014, 02:51 PM #4
My Daughter's house had people move out and had an indoor cat who's litter box located in laundry room was neglected for long periods. I used OdoBan® - Odor Eliminator - Home on the floating laminate flooring.After spraying this 5 years ago No Odor, No Problems and I didn't even have to pull up the flooring and replace the under lament just mix and spray. After a few days the "Added scent" was gone along with the Stale Cat Urine Smell.
11-04-2014, 03:15 PM #5
11-04-2014, 03:21 PM #6
11-04-2014, 03:27 PM #7
11-04-2014, 03:30 PM #8
11-04-2014, 03:58 PM #9
For my liking I would use soap and water and wash the walls, ceiling, and repaint, remove old carpeting, have the heat ducts cleaned. A bit of ole fashion elbow grease works wonders.
Also bbq charcoal put out in trays absorbs odours, also vinegar in trays is suppose to work but my monies with the charcoal.
11-04-2014, 04:11 PM #10
11-04-2014, 05:31 PM #11
11-04-2014, 06:05 PM #12
11-04-2014, 06:15 PM #13
Originally Posted by Kevin Wood
Not worth the time.
Kevin, go have a discussion with Ken ... maybe you two can tie each other up and not bother the rest of us.
11-04-2014, 06:46 PM #14
11-04-2014, 06:55 PM #15
11-04-2014, 06:57 PM #16
I would consider renting an ozone generator aka ozonator.
11-04-2014, 07:06 PM #17
Kevin
The home page of the product you provided a link for offers a commission.
Is this just a side line for you or do you want to go at it big?
As an Allergy Store affiliate you earn commissions 10% on product sales
11-04-2014, 08:56 PM #18
Rick,
Even if Kevin does not take any commissions ... he is offering up ADVERTISING as scientific evidence of some mischievous misdeeds by others? That's like offering up a GM advertising brochure as to why other manufacturers should be avoided.
(I'm not knocking GM, my wife's car is a Chevy Malibu - her 3rd Malibu, one of our daughters is still driving her last one / I had an S-10, followed by 3 Chevy Astro vans, then a Chevy conversion van, all of which I drove for inspections during my inspecting years, the daughter who is now driving the Malibu got the conversion van as it hit 99,000 miles when I retired from inspections, she drove it another 50,000 miles before getting the Malibu).
11-05-2014, 04:30 AM #19
The most impressive change was in my Grandmother's room, who lives with us. She has a multitude of problems and she needs a portable toilet in her room. As a result, it smells horrible in there. Once we put the zeolite in her room, the smell vanished.
11-06-2014, 09:34 AM #20
Good morning, Gents!
Thanks for the feed back! I will let you know how things panned out.
Let me add a little to comments on “carcinogens.” Most people incorrectly believe that the word “carcinogen” means “causes cancer.” Although that was originally true, that is not the current definition.
I suspect that if you look the word up in a dictionary or glossary, you will probably only find the commonly used definition. But to a toxicologist or an epidemiologist or pathologist (from whence comes our carcinogenic data), the word “carcinogen” has a very different meaning. Even buried deep in the bowels of our Code of Federal Regulations (Title 29 CFR, Part 1990.103) the word "carcinogen" is given the criteria I mention below, and doesn't actually include the word "cancer."
Contrary to common belief, there are actually very few confirmed human cancer causing compounds. My memory may be off by a little, but to memory, there are only about 23 confirmed “genotoxic” cancer causing compounds; 5 “epigenetic” compounds, and 5 that appear to be in a grey area. And yet we have hundreds and hundreds of compounds listed as “carcinogen.” So, from whence comes the difference? From the fact that a compound no longer needs to cause a cancer (a malignancy) of any parenchyma to be classified as a "carcinogen."
Like so much of science that has been high-jacked for social, political and ideological goals, the underpinning cohesive definition of "carcinogen" that emerges is actually a compound that results in one of the following physiological responses:
1) The exposed group develops an increase in all tumor types over that seen in the control groups. (Remember that the word “tumor” does NOT mean “cancer.”)
2) The exposed group develops tumors sooner than tumors seen in the control groups.
3) The exposed group develops types of tumors not seen in the control groups (this is subtly different than response number one).
4) The exposed group exhibits a multiplicity of any and all tumor types over that seen in the control groups.
In each case, the resulting tumor may be benign or malignant (non-cancerous or cancerous).
Next, while one of the posters expressed extreme fear over “chemicals” if one looks at an “organically grown” orange, or “organically grown” vegetable, and analyzes to see what is in it – that item is chocker block full of carcinogens, and chemicals, and chemicals containing multiple benzene rings, and aliphatics, aromatics, alcohols, aldehydes, ketones, esters, and all the other “chemicals” that often go into fragrances.
Humans are now, and from the very beginning of time, and forever more will be awash in “chemicals” and radiation and carcinogens… it’s called “Being human.”
(By the way, under on classification system, an hammer can be classified as a “carcinogen.”
Cheers!
Caoimh*n P. Connell
AMDG
11-06-2014, 09:03 PM #21
11-08-2014, 09:05 AM #22
Hello Billy –
You are correct. There are many compounds that can pass into systemic circulation through the skin or GI tract faster than through the inhalation route.
I performed an exposure assessment at a silk screening facility – some of the employees had free toluene in their urine even though the airborne exposure was being controlled – the primary rout of exposure was through the skin.
Cheers!
Caoimh*n P. Connell
AMDG
11-13-2014, 06:46 AM #23
Hi Caoimh*n, Good to hear from you, I always like hearing from you on environmental issues and always learn something. Cheers!!
http://acloserlookslc.com/
11-13-2014, 02:15 PM #24
"Nothing has the ability to kill confidence in scientific expertise more quickly than consistently incorrect use of capitalization, grammar, and punctuation."
Regarding citrus scent... if the scent is (for instance) limonene, is it better or worse if it was extracted from citrus rind or synthesized? Given two samples, how would you tell one from the other? And why is one better?
11-13-2014, 02:17 PM #25
