Thread: Radon discharge
    Default Radon discharge
    The house is on a hill side. The garage is in the basement. The radon pump in the garage. The outlet of the radon discharge is on the back side of the house, 18 inches above the ground, 24 inches below and 40 inches left of a window sill.
    Knoxville, TN
    Default Re: Radon discharge
    Maybe they used the right size and type of pipe? That would probably be the ONLY thing they did right.
    Nov 2009
    St Paul, MN
    It wouldn't meet the EPA guidelines and unless your state or local municipality have required installation standards there isn't much that can be done about it.
    I had a similar case here in MN a couple years ago where the mitigation system discharged at the kitchen window. Because the EPA guidelines aren't enforceable and mitigation installation requirements aren't covered by building codes here the seller couldn't be forced to fix it. Buyers walked though.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Knoxville, TN
    Radon is covered in IRC in Appendix F. In my area, builders are required to rough-in a mitigation pipe and cap it in the attic. Some take it thru the roof, some don't.
    Apr 2007
    WESTMINSTER CO
    RON
    any pictures
    cvf
Tags for this Thread
