Old 04-12-2007, 07:42 AM
Ron Bishop
Posts: n/a
Is this mold?
Is the white powdery residue in this photo mold? No moisture was present at time of inspection.
Home inspection
Old 04-12-2007, 07:45 AM
Scott Patterson's Avatar
Scott Patterson Scott Patterson is online now
Re: Is this mold?
Don't know. I would say it is a leak of some type. It looks like efflorescence, possible from a sink, toilet, tub, washing machine, etc. Salts/minerals from water.
Scott Patterson
Old 04-12-2007, 07:48 AM
Ron Bishop
Posts: n/a
Re: Is this mold?
Thank you Scott
Old 04-12-2007, 02:56 PM
Re: Is this mold?
Mold?
Well, *it is* "fungi".
And "mold" is "fungi".
But I would not want to go start chasing that "mold" dog down.
That "fungi" (it is a "fungus") is likely damaging the wood, did you jab your screw drive into the wood?
If the wood is soft and damaged, then it is a 'structural' problem/
Old 04-12-2007, 04:36 PM
Nick Ostrowski Nick Ostrowski is offline
Re: Is this mold?
How did it taste?
  #6 (permalink)
Old 04-15-2007, 06:32 AM
BARRY ADAIR's Avatar
BARRY ADAIR BARRY ADAIR is offline
Re: Is this mold?
"If the wood is soft and damaged, then it is a 'structural' problem/"
The problem was present befor it got wet, NO joist hanger present.
Residential-Commercial-Construction-EIFS-Infrared Thermography
  #7 (permalink)
Old 04-23-2008, 09:34 AM
Greg D. Dames's Avatar
Greg D. Dames Greg D. Dames is offline
Re: Is this mold?
Ron - Were you able to isolate where the water source was coming from.
I don't believe that the white power is mold I think that Scot has aim on what your seeing. Although the darker sections maybe supporting some dormant fungal activity especially if the woods moisture level is as your indicating dry 12% and below.
The water source may have had something in it that has left the white residue or crystals (salt?)
It appears very different than the plaster residue that we see on the subfloor framing on older homes.
Regards
Greg D. Dames
National ThermoGraphic Inspections
Pacific Mold Assessment
  #8 (permalink)
Old 04-23-2008, 01:35 PM
Gunnar Alquist's Avatar
Re: Is this mold?
Ron,
Is there tile above? Might be minerals like Scott said.
What is the circumference of a moose?
  #9 (permalink)
Old 04-23-2008, 02:02 PM
Ron Bibler Ron Bibler is online now
Re: Is this mold?
Looks like a past water stain from a shower or bath room.
What is the location?
Best
Ron
  #10 (permalink)
Old 04-23-2008, 08:33 PM
Raymond Wand Raymond Wand is offline
Re: Is this mold?
Without testing who knows?
These stains could be the result of the leak causing break down of the glues in the plywood.
The value of experience is not in seeing much, but in seeing wisely. - Sir William Osler 1905
  #11 (permalink)
Old 04-24-2008, 04:46 AM
Steven Turetsky's Avatar
Steven Turetsky Steven Turetsky is offline
Re: Is this mold?
Ditto post #4.
homeinspectionsnewyork.com
eifsinspectionsnewyork.com
  #12 (permalink)
Old 04-24-2008, 08:01 PM
Re: Is this mold?
Without testing no one knows for sure.
Beyond that, the picture is very typical of plywood that has been soaked with water, dried and re-soaked repeatedly over time. I've seen this often.
What it is isn't as important as noting the damage and possible consequences in your report.
Good luck.
847/736-9975
Markus Keller
Similar Threads
Mold and/or Radon testing.. Jason Welch Polls and Surveys 45 08-11-2008 07:28 PM
vB.Sponsors
Ad Management by RedTyger
