12-15-2007, 12:42 PM
Oil spill from burner filter
Other issues with this boiler/burner aside, what sort of clean-up is required where there is oil leakage onto an interior concrete slab?
12-15-2007, 01:08 PM
Re: Oil spill from burner filter
[quote=Michael Thomas;27390.. what sort of clean-up is required where there is oil leakage onto an interior concrete slab?[/quote]
Michael,
EPA or Get it Clean?
Kitty litter and Garage floor cleaner (Auto Parts Store) cleans it.
Billy J. Stephens HI Service
12-15-2007, 01:20 PM
More like "full compliance". Around here I rarely see an operating oil system, the concern is mostly buried tanks from decommissioned oil burners. And I was wondering if that degree of spillage could be a big an issue as say a slow drip from an interior tank.
What's the correct recommendation when reporting this, and what's my documentation for it?
12-15-2007, 01:55 PM
Try this. Scroll down to Oil Line Leaks. Other good info also.
Defects in Heating Oil Tank Installations, Oil Tanks, and Heating Oil Piping - Home Inspection Report Language
Dave
12-15-2007, 02:55 PM
David,
Thanks. I found this interesting as well: "(also) air may be drawn into the oil line when the fuel unit is pumping, this can lead to improper system operation and even loss of heat in the building. " Had not thought of that.
12-15-2007, 06:57 PM
Michael, any good HVAC supply house carries special deodorizing oil dry for such small spills such as Sweet Air Powder by Com-Star. It is essentially Fuller's earth ground into a fine flour, which when rubbed in will draw oil out of the pores of the concrete. I speak from first hand experience. If you had gallons that flooded under the slab, then it becomes either a hidden defect or major bucks to repair.
A Tiger Loop will remove the air.
HTH,
Bob
12-15-2007, 07:16 PM
Thanks!
| Thread Tools |
Search this Thread |
