LinkBack (1) Thread Tools Search this Thread
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 04-22-2007, 11:52 AM
Mike Huppi Mike Huppi is offline
Sewer gas smell in home.
I was asked to go to a home and see if it was accessible to go into the crawl space, they were told it was very tight.
I went by the home with the buyer agent and as soon as we entered the home there was a very strong smell of sewer gas. The agent said the sellers agent stated that it was from a pet turtle in the back bedroom causing the smell. We went to that bedroom and it smelled better in there than the rest of the home. I told here that it smelled like sewer gas and she agreed, the buyer father smelled the same thing. The access was not safe to enter and almost impossible due to it was a hole that was cut into the wall that was 4' above the floor and was 10" wide and 18" tall. A person would have to be very skinny and have two ladders on on the inside of the wall cavity and one on the outside then have to go in on their side without breaking something. Then there is another hatch in the floor to go through so I could not get to it at all. It was not safe or accessible.
When the 1st hatch was opened to look into the cavity the smell about knocked you over it was bad. The agent said the same thing and could not stand the smell.
I said that there should be a new access made and that the home owner not stay in the home until the smell is identified and repaired, and anyone who enters the space wear protective breathing gear until it is identified.
The seller is now stating that there was no sewer leak and the black nasty water is normal in the crawl space in that area. Yea right even if I could have opened the lower hatch I would have said the same thing.
She has filed a claim stating that I blew the deal and made unwarranted claims or statements.
If you smelled something that bad would you recommend that the person no mater who they were get it checked out and not stay there until they find out what was going on? I consider it hazardous and unhealthy and responsible on my part to point it out that there may be hazardous conditions.
Any opinions
Home inspection
Old 04-22-2007, 12:03 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Re: Sewer gas smell in home.
Quote:
Who did she file a claim with? Does that mean she is suing you?
I would have probably reported the conditions the same as you except I doubt I would have recommended the occupants vacate the house. Otherwise facts are facts and you simply reported the facts. It's not your fault her house is full of sewer gas or worse (e.g., broken sewe pipe).
Bruce Breedlove
www.avaloninspection.com
Old 04-22-2007, 12:23 PM
The the state contractors board. Because it smelled so bad I felt like if someone got sick after I was there then I could be held liable for not saying that there might be a health risk until it is found out what was causing it.
If you saw or smelled something that could be hazardous to someone shouldn't you let them know. Or if someone got sick they could then say that you or I should have said something.
Its kind of a catch 22
Old 04-22-2007, 12:26 PM
You did not "blow the deal", you reported the facts and made recommendations based on what you found. You did not say "don't buy this house" did you? Sounds like you identified a problem and called it out.
Who did she sue?
How did you find out?
Sounds like there is a lot of hot air in addition to the odor.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 04-22-2007, 12:34 PM
Are you licensed under the state contractors board? If not, it should be dismissed as 'not within the scope or purview of the board'.
Yes, if it's (in your opinion) a safety/health/life safety issue, you should report it to the occupants and advise them to not go back in until the (whatever) is ascertained/verified/repaired/found not to be harmful.
If you saw arcing or a flame flickering, wouldn't you tell them to immediately call an electrician or the fire department, or would you let them go back in knowing they may never come back out alive?
  #6 (permalink)
Old 04-22-2007, 02:20 PM
Scott Patterson's Avatar
If I had a dime for every homeowner, builder or agent said they were going to file a complaint against me for "killing the deal", I could by a Starbucks Double Espresso!
Don't worry about things like that, they tend to never mature or even happen. Folks say all types of things when you start messing with their money!
Scott Patterson
  #7 (permalink)
Old 04-22-2007, 02:28 PM
In Oregon we have to have a contractors lic. to be a home inspector. NO I did not tell them not to buy the house.
I got a registered letter saying that they are giving me 30 days notice that they are filing a complaint with the contractors board, which is required here. I am not to worried about it. I just thought I would find out if anyone else has had this problem like this one.
Thanks I will keep you posted.
  #8 (permalink)
Old 04-22-2007, 03:03 PM
Wow.
What does it take to become a licensed contractor in Oregon, and 'what type of' "contractor" must one be?
  #9 (permalink)
Old 04-22-2007, 06:57 PM
william siegel's Avatar
william siegel william siegel is offline
How about calling the building department and / or health department and reporting the issue. I'll bet that would end this real fast.
Bill Siegel
Florida Home Inspection Team Inc.
  #10 (permalink)
Old 04-22-2007, 07:17 PM
All home inspectors in oregon have to have a contractors license, liability insurance, bond, and pass the tests. We have to have 30 hrs continuing ed hours every 2 years.
I dont think the idea of the health dept is a good idea because I did not see anything I just smelled it and make my recommendations. The sellers agent sent me a picture of the crawlspace and it is nasty with black standing water that I would not enter the space even if I could walk into it.
I will try to resize the picture so I can post it.
  #11 (permalink)
Old 04-22-2007, 09:10 PM
Mike,
Quote:
What does it take to become a licensed contractor in Oregon?
What type of' "contractor" must one be?
  #12 (permalink)
Old 04-22-2007, 10:13 PM
It is just a contractor license that is for that type of work. Plumber, Electrician, Home Inspector.
In Oregon we are not allowed even if our lic allowed it to do work on any home or building that we have inspected in the last year.
On our license it states what we are a contractor for.
Mine only says home inspector.
Does that answer your question or explain it fully, if not let me know
  #13 (permalink)
Old 04-22-2007, 11:17 PM
So a home inspector is considered a contractor in Oregon. Interesting.
Bruce Breedlove
  #14 (permalink)
Old 04-23-2007, 12:29 AM
Tim Moreira's Avatar
Tim Moreira Tim Moreira is offline
If you can smell sewer gas in the home then it is a safety hazard and the client/seller/agents need to be informed.
  #15 (permalink)
Old 04-23-2007, 06:35 AM
Mike,
That answer the 'what type of contractor' question I had.
Being as you are considered a 'contractor' in Oregon, I would read up on any laws and regulations governing 'contractors' (and I am sure you have) so you will be aware of certain requirements which may now apply to you.
In Florida, Chapter 95, Limitations, would put you on the hook for a maximum of 15 years, if we (HIs) were contractors.
Then there are all of the requirements in Chapter 489 which would apply ... but let's not go there.
My other question was 'what does it take to become a contractor', in this case, a 'contractor - home inspector'? What qualifications, tests, etc., or can anyone just walk in and buy a 'contractor - home inspector' license?
  #16 (permalink)
Old 04-23-2007, 11:18 AM
Bob Harper's Avatar
safety first
If you smell what reminds you of sewer gas and it is coming from a confined space as defined by OSHA, you cannot be held responsible for inspecting or accessing such a place within the scope of a home inspection. Just as with Level III inspections of chimneys, you have sufficient ground to recommend this compartment be inspected by a qualified contractor of agency complete with SCBA, 4in 1 gas detectors, pull a confined space permit and send the owners a certified letter return receipt you are advising them they could be in danger of various hazardous gases including but not limited to hydrogen sulphid and methane. Send a copy of this letter to this State licensing board.
It is always better to err on the side of caution and in the favor of someone else's safety. If you fail to notify the occupants of a hazard to them, you could be in more trouble. The blown deal is hot air. You did not create the hazardous condition. The owners put you at risk by failing to disclose a hazardous environment. Their listing realtor should have walked the house during the disclosure and flagged the odor then.
Put it back on them. You did your job and was put at unnecessary hazard through a failure to warn. You could have died in there if there was hydrogen sulphide gas accumulated. Anytime you guys crawl under homes or even enter basements, it would pay you to wear a 4 gas analyzer/ alarm-
combustible gas, O2, CO, and H2S.
  #17 (permalink)
Old 04-23-2007, 11:50 AM
Brian Hannigan's Avatar
Brian Hannigan Brian Hannigan is offline
Administrator
Here is information on Oregon Home Inspector Requirements
OR: Home Inspector Test Application Packet
BTW, are referrals from past clients important to you? If so, watch this Video
Sincerely,
Brian Hannigan
Hann Tech Marketing Links
http://www.HannTech.com
http://www.InspectionNews.net
http://www.InspectionRadio.com
http://www.CostOfBusiness.com
http://www.AccessMyReport.com
aaa-CaliforniaHomeInspection.com
http://www.HomeInspectorLocator.com
  #18 (permalink)
Old 04-23-2007, 02:37 PM
Thanks Brian I was not thinking and should have posted the link like you did. It must have been the sewer gas that gave me a brain lapse.
Mike
  #19 (permalink)
Old 04-23-2007, 03:46 PM
Thanks.
  #20 (permalink)
Old 04-24-2007, 06:20 AM
Caoimhín P. Connell's Avatar
Caoimhín P. Connell Caoimhín P. Connell is offline
Hi Gents –
Interesting thread. Two comments really got my attention:
(Huppi)
1)… and the black nasty water is normal in the crawl space in that area …
OK – That’s interesting. However, even if that were true (which is highly questionable), so what? That doesn’t make it OK; it just means that in that area, construction contractors or architects should be doing something about the intrusion issue for every house.
(Harper)
2) You could have died in there if there was hydrogen sulphide (sic) gas accumulated. Anytime you guys crawl under homes or even enter basements, it would pay you to wear a 4 gas analyzer/ alarm- combustible gas, O2, CO, and H2S.
Very true. In fact, depending on the SIC Code for Home Inspectors, HIs may very well fall under the requirements of OSHA’s confined space standard. If HIs are considered to fall under “Construction,” then you would be exempt, otherwise if you are considered “General Industry” then the entry procedures apply to you (and your employees), and the testing described by Harper may be mandatory for a large number of crawlers.
I think Harper’s advise is very sound.
Cheers!
Caoimhín P. Connell
Forensic Industrial Hygienist
Forensic Industrial Hygiene
<SMALL> (The opinions expressed here are exclusively my personal opinions and do not necessarily reflect my professional opinion, opinion of my employer, agency, peers, or professional affiliates. The above post is for information only and does not reflect professional advice and is not intended to supercede the professional advice of others.)
