Old 05-28-2008, 01:57 PM
Chris Parker Chris Parker is offline
Certified Terminte Inspector in Indiana
I've just about got everything together to start my business, and I was told by a friend who just bought a house that the I really need to be certified for termite inspections to get much work.
I've done some searching on the web and can't find anything that tells me how to go about this. Anyone have info on becoming certified for termite inspections in Indiana?
Old 05-28-2008, 04:29 PM
Richard Rushing's Avatar
Re: Certified Terminte Inspector in Indiana
Chris,
If you are new to the home inspection profession, you should certainly make sure all your ducks are in a row with respect to knowing that (home inspection) end of the business before trying to get into another inspection profession which requires a whole different type of qualifications, skill-set and experience that should be obtained through a mentoring program.
My suggestion to you would be to farm-out the requirements, if the buyers request you to do so.
Good luck with your start-up...
Richard
Richard Rushing, HCRI
Duncanville, Tx.
Old 05-28-2008, 05:33 PM
Kevin Luce's Avatar
Kevin Luce Kevin Luce is offline
To get licensed to do WDI inspections you will need to go to Purdue University. It is a great class and you will learn a lot. They charge very little but teach a lot. This is one area where they don't screw you over with the requirements/fees.
Becoming a WDI Inspector
Obtaining a WDI Business License
I say lets merge all the home inspection organizations into one.
Seepaluce
Old 05-28-2008, 07:18 PM
Jon Randolph Jon Randolph is offline
As bruce stated above, go to purdue. You also need insurance that covers WDI inspections.
It is good to be able to provide all of the services, but that is not always feasible, especially when starting out. The important thing, in my opinion, is that you are able to provide all of the services needed and that the client does not have to cal 3-4 companies to get all that they need.
I subbed WDI insepctions my first year and a half, until I decided that I was going to get enough business to stay busy and justify the extra expense with licensing and insurance. It's not a bad idea to get the certification now, but it is not necessary so long as you are able to still provide the desired services through other vendors.
You are not that far from me. If you decide to wait and need to sub this out, contact me and I may be able to help. I do perform the WDI inspections under a different company entity than my HI business.
I can also give you the names of the companies that I use for radon testing.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
Similar Threads
Indiana licensing needs an improvement Kevin Luce Business Operations: Home Inspectors & Commercial Inspectors 10 06-16-2008 10:03 AM
new inspector from indiana Kevin Rutledge Introductions By New Members 5 02-28-2008 05:28 PM
Move In Certified Deleted Account Business Operations: Home Inspectors & Commercial Inspectors 19 09-21-2007 10:54 AM
Certified, certified, certified.... Jack Feldmann Associations, Ethics, Standards, Licensing, Legislation:Home Inspectors & Commercial Inspectors 10 08-04-2007 09:43 AM
Certified Pool Inspector ? Rick Hurst Pool and Spa: Home Inspection and Commercial Inspection 11 04-24-2007 07:36 AM
vB.Sponsors
Ad Management by RedTyger
