Thread: Gaps between siding and stone
06-10-2009, 07:25 PM #1
I pointed this out on an inspection today and several people involved didn't seem to think it was important. Any thoughts from our masons and siding contractors. I am recommending correcting the gaps, but now I am second guessing myself.
06-10-2009, 07:37 PM #2
Re: Gaps between siding and stone
Only reason you'd want to seal those openings would be to keep out any moisture or insects which would be a bad thing. Right?
06-10-2009, 07:39 PM #3
Hard to tell from the pics but it looks like the joints are somewhat protected from falling rain. Driving rain may be a different matter.
The gaps could be an entry point for insects and other vermin. If for no other reason, the gaps should be sealed for draft protection.
Let's see, weather intrusion, insect & vermin infestation, draft protection. Yeah, I would say they should be sealed.
06-10-2009, 07:44 PM #4
Look at the last photo with the mortar next to the beam ... is that what you really want?
That will/can cause the beam to wood decay.
You WANT that gap with no mortar.
THEN you want that gap with no mortar sealed with a good sealant.
And they need to do something about the mortar up against that laminated beam.
06-10-2009, 07:50 PM #5
Thanks for the info.
06-10-2009, 08:33 PM #6
If there is rain it does not have to be blowing directly into the crack to get moisture in the joint as Mr. Ramsey mentioned. Stuff a piece of tissue paper in the crack and check it out after a light rain. You will find it is damp.
06-10-2009, 09:44 PM #7
Agree with Jerry. Backer rod and sealant for me..
sm
