Thread: Strong as the weakest link
09-05-2009, 05:27 AM #1
No support posts, just the chain! And not sure how this was anchored under the soffit, my guess it was into the end of a rafter.
09-05-2009, 08:34 AM #2
Re: Strong as the weakest link
Raymond, that deck appears to be supporting the house pretty well!
I see the chain is adjustable, so they can take up the slack now and then.
09-05-2009, 05:47 PM #3
Good timing! This was in today's New Zealand Herald.
09-06-2009, 09:36 AM #4
09-18-2009, 10:18 AM #5
Raymond
Although it is possible to support a cantilever deck by a chain or cable it is not typical. From an engineering standpoint the chain may be strong enough to hold up the load, but the issue I see is the design of the connections. It appears the upper part of the chain is connected to a wood screw type eye-bolt. The question is, what is the pullout capacity of the eye-bolt?
Also what is the other end of the chain connected to? This is a case where you should call this out as a possible safety issue and recommend this be evaluated by the building code inspector or structural engineer.
09-18-2009, 01:33 PM #6
Don't know what the eye hooks were fasten to. Told clients to remove chain and install support posts, or to rebuild the deck the right way.
Cheers,
