Results 1 to 17 of 17
Thread: Handrails on deck
10-04-2009, 09:22 AM #1
Handrails on deck
disregard this post
Similar Threads:Last edited by Ryan Stouffer; 10-04-2009 at 09:35 AM.
10-04-2009, 09:38 AM #2
Re: Handrails on deck
Just clarifying, yes, that needs handrails.
10-04-2009, 09:41 AM #3
Jerry, it does need handrails because it is considered 4 or more risers. Correct?
10-04-2009, 09:43 AM #4
Ryan,
Correct.
10-04-2009, 09:54 AM #5
Thanks. With rookies like myself, I just want to make sure.
10-04-2009, 02:08 PM #6
disregarded!
10-04-2009, 09:50 PM #7
LOL it's only 3 1/2 risers, which brings another code issue into play.
10-05-2009, 09:14 AM #8
What is the code for steps? I thought you could have 1 step without a hand rail, after that you needed something.
10-05-2009, 11:52 AM #9
4 or more risers.
10-05-2009, 12:15 PM #10
whose the moderator
10-05-2009, 02:57 PM #11
Any change in elevation is a "riser", which must conform to the dimensional tolerances of the code and the maximum variation from the other risers.
I'm not sure what the UBC says.
Usually the min-max riser can be at least 6" to 9.5 max.
The tolerance for multiple risers are + or - 1/4" at the most.
A hand rail is not required if the top landing is not over 24" from grade. So that is where the 4 riser comes into play.
If the stairway, deck, etc., is more than 30" high above the level below, then a guard rail is required. Maybe that is what you were thinking of?
10-05-2009, 09:30 PM #12
In my State (Mass.) 3+ risers require handrails regardless of related heights.
(e.g. 30" for decks, landings,etc)
10-08-2009, 06:09 PM #13
10-09-2009, 12:29 PM #14
Ben,
There still is no conflict.
That does not mean one does not, should not, use common sense for each of the two distinct and different things.
If you have 4 risers of 7" high then the total height is 28" - which means no guard on the stairs and no guard on the deck, but it does required a handrail on the stairs.
If you have 4 risers of 7-3/4" then the total height is 31" - which means a guard is now required on the stairs and on the deck, along with the handrail on the stairs.
However, each (the guard and the handrail) serves a different purpose.
10-09-2009, 01:52 PM #15
01-29-2010, 01:55 PM #16
Not only that stair needs a handrail but the BC code suggest If width is more than 1100mm a handrail is required to have both sides of the stairs.
01-29-2010, 08:00 PM #17
