Thread: deck stairs
02-25-2010, 06:20 AM #1
deck stairs
How do you like this stringer attachment?
02-25-2010, 07:53 AM #2
02-25-2010, 08:42 PM #3
02-26-2010, 06:47 AM #4
Re: deck stairs
Simpson LSCZ. They're not that expensive but most big box stores don't carry them therefore deck "builders" aren't likely to use them.
02-26-2010, 09:02 AM #5
Re: deck stairs
Definitely should have a mechanical fastener such as a angle plate.
02-26-2010, 11:07 AM #6
Re: deck stairs
Toenails are actually sufficient (well, when done properly they are - those in the photos do no fit that category) as the angle of stair stringers works to transfer some of the loads laterally at the deck. The problem with toenails is that I've never seen them done properly. Wrong fastener size, wrong angle, wrong spacing, wrong number, insufficient header, and insufficient top riser height are the usual culprits.
I always use mechanical fasteners to attach stair stringers to the deck, whether they're inside or outside stringers. Why gamble?
02-26-2010, 11:36 AM #7
Re: deck stairs
And a framing nail is not just a framing nail. There are hand-driven nails, both common and box, and then there are the more often seen pneumatic nails with smaller shanks and some with clipped heads. All of these nails perform differently regarding their withdrawal strength load values.
http://senco.com/pdf/facts/ner272.pdf
It is also notable here that Senco, for one, recommends only stainless steel fasteners for framing exposed to the elements, especially when using pressure-treated lumber.
02-26-2010, 11:48 AM #8
