Results 1 to 10 of 10
		Thread: Exterior LVL
	04-13-2010, 06:40 AM #1 Exterior LVL Exterior LVLI could not find anything on this. Do you know if this type of LVL is rated for exterior exposure.
	04-13-2010, 06:52 AM #2 Re: Exterior LVL Re: Exterior LVLNo - does not appear to be approved for exterior use based on #5.3 of the attached PDF; Never mind, I can't figure out how to attach a PDF, I'll PM it to you in a minute.
 I did some research on exterior LVL's a few years ago. From what I vaguely remember exterior rated ones are much darker in color. Sorry don't remember anymore than that.
	04-13-2010, 06:54 AM #3 Re: Exterior LVL Re: Exterior LVLThanks
	04-13-2010, 10:35 AM #4 Re: Exterior LVL Re: Exterior LVLDo you see the label where it says ESR 1210? That means there is a report on file with the ICC. Here is the link to the report.
 http://www.icc-es.org/reports/pdf_fi...S/ESR-1210.pdf
	04-13-2010, 11:04 AM #5 Re: Exterior LVL Re: Exterior LVLIt doesn't directly address rating regarding exterior exposure.
	04-13-2010, 11:25 AM #6 Re: Exterior LVL Re: Exterior LVLSo that means that it is not rated for the exterior!
	04-13-2010, 11:27 AM #7 Re: Exterior LVL Re: Exterior LVLWell that would make sense
	04-13-2010, 11:49 AM #8 Re: Exterior LVL Re: Exterior LVLMatthew, if you read #5.3 in the ESR, it states, dry condition of use, covered and no more than 16 percent moisture content.
 I don't live in your location but I doubt Utah weather would comply with that. Therefore, NOT approved for exterior use.
	04-13-2010, 11:52 AM #9 Re: Exterior LVL Re: Exterior LVLThe main point I was making is that you can find information on an item when it (the item) has the ESR number on there.
	04-13-2010, 11:53 AM #10 Re: Exterior LVL Re: Exterior LVLMarkus, thanks. I can't seem to bring that report back up.
